Received FOR kit...kinda
OK, that makes sense when the lift amount changes.
However if you draw out the actual angular change with OME bushings or our bushings and then install them and have the pre and post caster measured they are not the same as the simple 2D angular measurement from the bushing geometry.
OME bushings measures out to something like 3.4 degrees, however if you install them, you most always see 2 degrees change as measured on an alignment rack. That is on a truck where the height did not change (maybe minimal) on pre an post caster correction.
I have never been able to determine if a alignment machine simply measures the caster as we perceive it as an angle forwards or backwards from the center of the axle or does it also take camber into account and the caster angle is adjusted when measured on a machine.
After putting the springs in and prior to caster correction the spring perches are angled to each other and the spring is formed into an arch. After installing some correction that anglarity in the perches is reduced and the springs are now straighter to one another. On my truck I saw a 1/2" gain in height when measured from the fender to the hub center after installing my plates. That added lift after correcting caster means that I needed yet more correction to compensate for that 1/2" that wasn't there before.
I can see that, but didn't we conclude that caster changes about 1.7 degrees per inch of lift, so theoretically you should have been only about .85 degrees short?
My comment about how he got more than expected was that maybe he didn't get that additional bump in height so it looks like he got more correction than expected. But then again Frankies springs aren't flat on the ends and maybe that plays into it as well.
I just wanted to clarify in my mind what you were referring to.
correct, however I had your first run front springs which were a little short so I was making up for falling short because of the bump in height and needing more from the longer spring as well as aligning for a DC shaft. It all seemed to come together rather nice, it just took me two tries to get there.
Rick, we have always seen this as well. When you draw it out, you get a certain amount of axle rotation in degrees and when you have the caster measured, it is not the same. However I don't follow what you are trying to say below?
I don't see how this affects the caster reading. I can see how different rotation methods change the net amount of lift, but not the caster reading. I always thought it had to do with the fact that we look at a caster change in simple 2D (from the side), yet the caster readings are made using a sweap, so some sort of averaging comes into play.
Or do you mean that the axle is rotated one way (backward for positive correction), yet part of the affect is that the lift (distance between axle and frame) raised the rear of the arm, thus rotating the axle forward again?
If you read through my plate thread you will see that my first drilling was at 5* of rotation but ended up falling short of my target as we all see now. I then plugged those holes and added 2 more degrees to make up for what I fell short and some more for the anticipated added height of getting the perches even better aligned.
AHHHHHHHH!!!!.....:confused::bang:
Thanks for making it "clear" for a newbie. :D
Oh well....off to the :beer::beer::beer::beer:. I think that will help.
I wonder if he (or frankie) sent you the 2 degree ones instead of the threes. He was kind enough to send me a set of twos and threes, and I definitely got 3 plus degrees of correction from mine.
It sounds like he sent me the 2* bushings instead of the 3. I will install the 2* and see what I get out of them. If I still need more I can always switch them out for 3* or go to plates.
Since I was sent the install sheet and it had two bushings listed I was able to draw both templates.
The bushings that have a centered bolt hole are 3* bushings which will yield 2* of correction
The bushings that have an offset bolt hole are 5* bushings and will yield approx 3.5* of correction.
Hope this helps
So, which set should he use wit his lift? the 3*/2* or the 5*/3.5*?
it depends on the height of the truck. You can't simply match a spring to a correction method. You have to consider how much the truck weighs and the height of the truck after the install.
The 5*/3.5* bushings will work for trucks up to a hub/flare measurement of 22.5". Above that height and you will start to fall under the 2* spec and the handling will degrade.
Uh oh.....center of hub to flare measures just less than 23.5 but that is without sliders and bumpers.
22.5" is OME medium since stock is 20.5". If you follow this statement, all lifts above OME medium height on the front end require caster plates and a DC shaft or will suffer handling degradation (and all OME medium kits are not sufficient, which I'd agree with in terms of pure caster measurements to stock specs). I'm not debating the math - the question of noticeable degradation between say 1* and 2* is certainly debatable in interpreting the phrase "will work".
An 80 that is about 2* below spec still has a pretty good return to center feel. It's not perfect, but until you've driven with caster so out of spec that the rig literally cannot drive in a straight line but rather zigs and zags can you perhaps say on a 3.5" lift that a degree of caster is going to be pretty damn good. Not looking to start a debate here - I just don't think it is a black and white "2* and above is fine, under 2* is not" analysis. Lots of gray in how much one degree of caster really matters depending on where that one degree happens to fall in the readings.
I'm going to actually test this statement by changing from OME CC bushings to the Slee blues. I'm at about zero now, so should end up between 1 and 2 degrees. I'm not concerned about that being enough caster, but I am concerned about an additional 1.5* of pinion u-joint angle causing vibes, in which case then I get to test CC plates and a DC shaft, which means I'll go back to the OME bushings since I don't have $800 to drop on 2* of caster right now.
22.5" is OME medium since stock is 20.5". If you follow this statement, all lifts above OME medium height on the front end require caster plates and a DC shaft or will suffer handling degradation.
Not you too.
It has nothing to do with the advertised lift dimension, it's the height of the truck after the springs are installed which is relative to the weight of the truck.
TOY350 has Js on his truck with no additional weight and needed plates
Romer has the equivalent (850s+1" spacer) on a very weighted truck and OME bushings work fine.
Those two trucks have very different caster correction needs do to the weight of the accessories and the gear they carry.
so does this mean that depending on whether the truck is loaded up to go on an expedition or just as a DD, this will affect the castor correction?
If so, then what should we do to compensate?
I for one use my truck as my DD but when we go on trips with the family, there is a heap of stuff in the back that there is a droop if only a tiny one. Of course it's usually the back only that gets most of the gear and the front is not usually affected.
But when towing something heavy there is a very noticeable sag in the back. Is this where some other form of leveling is needed? say air bags?
The rear does have an effect on caster but not that much. And since lowering the vehicles height increases the caster it's not a concern unless pushed to the extremes.
If you are still running the stock springs I'd look at the OME low lift springs especially if you do tow at times. Big improvement over stock.
And the effect on caster shouldn't be any different on a lifted truck with correct caster as it is on a stock truck that is loaded down. And I'd bet a Shinner Bock that the caster is still acceptable all the way up to max load and above on stock set-up. That's just the way Toyota Designers Roll....
Nay you've edited your post.
I personally am not comfortable suggesting people set there trucks up with an alignment that is out of spec. I simply try and inform them what is needed to correct for the lift to get the alignment numbers back where the factory wants them.
Fair enough. That's different than "will work", and opens up an entire debate as to whether what the factory wants is the right solution for every possible suspension and tire setup.
I'll give you a more extreme example than we are discussing here with a F.O.R. lift. Factory spec on an XJ with the stock short arm four link suspension is 7*. If you got below about 4.5* it would wobble, and much lower and it would not even drive straight down the road over 55 mph. I took this same rig with same lift and converted it to a 36" long y-link radius arm setup and ran caster at 2 degrees very effectively. Definitely not where the factory wanted it, but it was where the vehicle wanted it on 7" of lift and large MT's with a different suspension linkage.
My only point in saying this is not to contradict your good advice - I'll agree an 80 at the low end of caster spec is a good idea given the overall reports from users (at zero it is a little bit darty). What I don't agree with is the excessive discussion on this board that treats caster as an independent variable. Do you necessarily want the exact same caster function on a 33" Revo and a 37" IROK on two totally different lifts expecting the same outcome?
The reality in any case is that unless you are willing to cut and turn or build a new front end, caster is never the leading alignment variable. Pinion angle is because you need to care for vibration due to misalignment first. You may not be able to use Slee blues on a 3.5" lift without front end vibes due to stock driveshaft u-joint angle misalignment. So that means a DC shaft and plates, and caster is what it is (maybe pushing spec on the upper end).
If we accept the idea of "will work" means a vehicle that does not have driveline vibration induced by caster correction, then the number of true caster set points is fixed by pinion alignment, luck (my setup on OME bushings alone should by all accounts vibrate but doesn't), and the two driveshaft style options. The factory wants your driveline not to vibrate before it wants your caster to be in spec, and this is a crap shoot in the CC bushing vs. lift height with stock driveshaft equation.
The real question is taking the risk of high angle correction bushings and guaranteed out of spec u-joint operating angle alignment (this is the "hope it doesn't vibrate") approach, or going to plates and DC shaft. By your math, this decision occurs at any net lift above 2", and I would agree with that on every point.
BTW, I've wheeled with Romer and he has as much lift as I do and is well out of spec if he only has OME CC bushings like me. I have a set of Slee blues and your template sitting on my desk right now. It will fix my caster, but it may "un-fix" my vibe free ride. Given if it vibes I'll need a DC shaft and maybe plates (depending on total Blue correction that may actually set it up for a DC), I just rolled a $500-$700 set of dice betting on only spending $200 of that. We'll see.
I doubt very much you will have any vibrations with Slee's bushings and my template. People have actually gone from a vib problem to vib free by using the template. I can't explain it but by rotating the axle on it's axis seems to make a difference.
I understand all the u-joint angles but for some reason the front shaft on these trucks tend to be very forgiving.
Yea, I've read all the reports, and it's why I'm taking the shot. Let's call it engineering voodoo and just say it's a no-brainer :D
