Received FOR kit...kinda
you probably need to just change out all 4 u-joints then.
I thought the grrrr was from the castor being way off after the lift. So you feel that the castor correction wont cure the noise then?
the Grrr is typically from lifting and then correcting for caster to a point where the drive angles won't work for a stock shaft. Then you would need to replace the front drive shaft with a DC shaft provided the new angles were set up for that style shaft.
Since all that you've done is install the springs and NO caster correction then the stock drive shafts should still run Grrr free provided the u-joints and slip yokes are still good.
I'm not sure how much correction that Frankies bushings provide so I can't say what the outcome will be after installing them.
Well I guess it's just a wait and see how it runs once the bushings are installed.
Well I received my FOR kit from Frankie and there were so many parts missing I thought there had to be a third box. (The 2 boxes i did get looked like UPS had run over them a few times)
I called up Frankie the next day and let him know that I was missing some parts. He said that they were all in the box when they left his shop and the parts must have been lost on the way. I would have to believe this based on the condition of the box and the fact that the label said it weighed 40lbs and was 31 on my scale.:hhmm:
He called UPS and they were only mildly helpful so he said he will 2nd day air the missing parts to me and deal with UPS on the missing equipment.
I wanted to let everybody know that Frankie was very professional and apologetic and just wanted to make sure I was taken care of.
This is the sole reason I'm now a FedEx customer, although have to drive a little further to get to a FedEx store. UPS has lost my shipment twice in 4 months and all they did was just a refund for the actual shipping cost plus $100 (and it took 4 weeks to get a lost shipment notification plus another 3 weeks to get a check. :mad:
Not to mention about VERY poor customer service.
UPS = Ultimately Poor Service. :censor:
On the FOR lift your angles should be ok - have the rear driveshaft balanced. Mine did the same thing, got a bit worse over time after several offroad trips as I candy caned it a bit. $50 for a rear driveshaft balance and the rig is smoother than it was when I bought it with OME medium installed.
Thanks Nay. What castor correction are you using...bushings, plates, etc?
Cool, its looking good, I bet you can't wait to get those 35s on there.
I think you will be very happy with this setup.
:cheers:
:cheers:
Yes...I can't wait to spend $1300 on tires.
I still have OME CC bushings installed in the classic 6 o'clock / 12 o'clock positions that were on the rig when I bought it. It drives as well as it did at the OME medium lift height. Which is to say that OME medium CC is not really enough either, but in the world of lifted solid axle rigs on 35's it's damn good. I've never been on a short or long trip where what was on my mind was caster over say scenery :grinpimp:
I'll probably do Slee blues since I have a LT template for them, but I consider that to be a luxury item and it's probably at least a year away.
I'd do the bushings that Frankie sent, and if you can wait and LT will do a template it will be worth it for accuracy of install at your shop. Cross caster is worse than low caster if they screw it up.
The front shaft (when balanced) seems extremely tolerant of angle offset, so I think you have a good shot of coming out clean with the necessary caster.
I understand where you are coming from as far as how well your truck feels compared to the other lifted ones you have driven, but honestly I think you would change your mind on it being a luxury item if you took the time to setup the truck properly.
As much as it pains me to wait for a LT template, I will send off the bushings to him today. These will be some well traveled bushings: AL to CA to MA and back to CA.
sweet. I will get with LT after he has a template for them.
Once I have bushings and ther arms off I might think up a jig based on the LT template and have it laser cut basedb on the teplate.. I am surprised that some shops are'nt offering a arm exchange program where you send yours back as cores and get rebushed ones shipped with the lift.
Of course. The name of the game is self delusion until you get around to doing things right. And then once you do them right, you can put out a post about how you knew all along that your next project was going to be the bomb and change the way you think about things. The space between the two is directly proportionate to 4x4 project budget allotments :grinpimp:.
I don't daily drive my 80, so it's not chomping up the list of spend items I have that are non-80 related that I don't have any money for, either :D.
But I know. I spent $4K on an Ford D44 axle on my old XJ just because I had no other way to correct caster and retain AWD, and retention of AWD for family safety in my climate was an absolute. A couple hundred bucks of bushings and install is nothing. Unless of course it causes vibes and you have to go with plates and a DC shaft, in which case you're pushing $800 by the time you're done (assuming the DC shaft runs clean). I've been through the multi-year caster v. vibes fight, and my rig is 100% smooth throughout the driveline. That is huge.
Coming from a world where you had to balance angles between caster and vibration in AWD (no option on a Jeep to go to a DC shaft as it comes with one from the factory), the OME bushings would be a nice enough balance if anything more was vibration inducing. As alignments go, the first setting is no vibration. Everything else has to follow.
My pre caster bushing numbers were L -2.2 and R - 1.5 After I installed Frankie's 3 degree correction bushings, I came out with L +1.9 and R +2.2 Good choice on sending the bushings to Landtank to make a proper template, that would have been the smart thing for me to do as well.
not bad, you got 4* of correction from a 3* bushing.
I remember seeing on slees site that even the OME 2* bushings really can correct up to 3.2* or something. I am not too surprised that a 3* advertised bushing can actually do about 1* more as well.
with all caster correction you never get the amount that you actually move the axle by. I've drawn up all the methods now and the end result is always short of how much change you made.
I feel that this is do to the fact that as you rotate the axle the spring begins to straighten taking some of the arc out of it which results in a little more lift gained from being able to support the load better. I saw this on my truck when I corrected for caster. This added height now increases the need for more correction resulting a lower caster reading.
Since he was able to get results higher than expected I'm inclined to think he didn't get the expected bump in lift. Pressing in any of these bushings following the diagram will get much varied results.
Rick, we have always seen this as well. When you draw it out, you get a certain amount of axle rotation in degrees and when you have the caster measured, it is not the same. However I don't follow what you are trying to say below?
I don't see how this affects the caster reading. I can see how different rotation methods change the net amount of lift, but not the caster reading. I always thought it had to do with the fact that we look at a caster change in simple 2D (from the side), yet the caster readings are made using a sweap, so some sort of averaging comes into play.
Or do you mean that the axle is rotated one way (backward for positive correction), yet part of the affect is that the lift (distance between axle and frame) raised the rear of the arm, thus rotating the axle forward again?
After putting the springs in and prior to caster correction the spring perches are angled to each other and the spring is formed into an arch. After installing some correction that anglarity in the perches is reduced and the springs are now straighter to one another. On my truck I saw a 1/2" gain in height when measured from the fender to the hub center after installing my plates. That added lift after correcting caster means that I needed yet more correction to compensate for that 1/2" that wasn't there before.
If you read through my plate thread you will see that my first drilling was at 5* of rotation but ended up falling short of my target as we all see now. I then plugged those holes and added 2 more degrees to make up for what I fell short and some more for the anticipated added height of getting the perches even better aligned.
My comment about how he got more than expected was that maybe he didn't get that additional bump in height so it looks like he got more correction than expected. But then again Frankies springs aren't flat on the ends and maybe that plays into it as well.
You have answered yourself. The difference in the net amount of lift is what he's saying effects the caster reading.
Say you lift 3.5" do a reading, and say you correct 3deg, you don't necessarily get 3 deg, because you don't have 3.5" of lift anymore, because of how the spring sits with the axle rotated, you now have 4" of lift.
