Rebuilt knuckles - leaking from the bottom
Denver, NC
Hi folks - about 9 months ago I completely rebuilt my knuckles using all new parts including marlin inner seals from our friends at @cruiseroutfit . Due to life issues the rig wound up sitting unused thereafter for around 6 months. When I was almost ready to get her back out on the road I noticed what appeared to be the fresh 90 weight I had replaced in the DIFFERENTIAL leaking from the bottom knuckle stud area on both ends of the axle.
Before I reluctantly tear back into it, is this normal for a truck that sits and should I drive her for a bit to see if it stops? I doubt I damaged both of those seals and it has had zero time in 4wd since.
Any ideas are greatly appreciated!
How much oil? What type of grease did you use during the rebuild? If synthetic, some types will liquify slightly and leak.
Not a gusher for sure. Just wet with 90w and some has dripped on the tires. I just used regular 90w - not synthetic and used the Mobil 1 from a tub to pack the birfs. I did put in new birfs that had red grease which I didn’t repack with the moly - wonder if it could be n interaction between the two?
Thanks!
You pumped the knuckle full of 90w oil or you packed it with grease?
No, replaced the 90w in the diff when servicing the knuckles. Definitely didn’t pump them full of 90w!
What @matzell says...and maybe you did it correctly but hard to tell by your post. Not supposed to put gear oil in the knuckles...only moly grease.
Gear oil only in the diff. Then the oil seal keeps the two lubricants away from each other. Let us know.
Folks, sorry and I have made it clear now in the original post that I put 90w in the diff and not in the knuckle housing. This is like the 10th axle I’ve rebuilt so I should have it down by now hopefully (yet still having issues with this one)!
To avoid any more apparent confusion, here are the lubricants and locations of application used:
- 90w Walmart variety filled in diff cover until even with plug
- upgraded birfs with red grease of unknown origin
- Mobil 1 Molly inside knuckles to 3/4 full
- standard red high temp bearing grease in knuckle bearings and wheel bearings
As to what I used to drive the seal, I used a seal driver set I borrowed from Auto Zone.
Thanks all
Remove the square plug from the back of the knuckle and stick a zip tie in, like a dip stick. If there’s grease in the knuckle and oil in the diff, I’d drive it a little and see what happens.
Well, I am in the same, did rebuild well, same 90 weight one side, proper grease the other, and, some leakage as well. Once the tires start to pin, no more. Perhaps some liquid getting past seals.
Do you mean my knuckles AREN'T supposed to leak all the time?
cheap grease that is separating?
seal damaged on install of the inner axle?
seal installed the wrong way?
mixed up shims when rebuilding?
What seals did you use? This knuckle was rebuilt about 10 years ago. Only about 4000 miles on it but not leaking. I didn't rebuild it but the guy who did used Marlin seals.
mine are doing the same thing - same situation except moly in the birfields and it's been sitting for a couple years now. i'm thinking the grease is separating a little - my grease gun does the same thing: liquid leaks out the bottom after sitting for a long time. since my rig will be sitting for a while longer, i jack it up and started rotating the wheels (hubs locked to turn the axles) - seems to have slowed down the leakage
Mine dribble a little ONLY after driving........ onto the 4 knuckle plate bolts :hillbilly:
*On the positive.... I’ve snugged up bolts on the oil pan and have gotten the old girl to stop marking her spot in the garage!
