Rear wiper doesn't work
There a wiper relay/control box inside the upper hatch left side panel that supplies power to the wiper motor.
Have you popped the cover off the base of the arm and tried tightening the nut inthere? Sometimes that's all it takes.
It sometimes works, but usually doesn't. It will always come on if I crack the rear hatch just a little.
Is there a common 'fix' for this? Bad ground? If so, where?
I have a similar but different problem:
If ignition is on, the wiper and upper rear window brake light don't work.
If ignition is off, the upper rear window brake light works.
Can you hear the motor running?
If the motor's running, but blade isn't moving, part of the linkage is stripped.
I have been chasing this problem as well now.
3rd Brake light, wiper and defroster stopped working. I was just in this area this weekend and checked the relay everything passed inspection. The motor looks fine and I couldn't see any bare wires or even broken sheathing for that matter. Everything was very tidy. I did notice that the power supply that feeds the wiper had a charred connection on the ground side (white and red wire connector). I cleaned it up and added a vehicle ground strap as a redundancy in this location. Tested the wiper and brake light and they both functioned perfectly. So I buttoned everything up thinking I had the problem fixed.
On my snowy drive into work today I tried my rear wiper and to my disappointment it is not working again. I am thinking my best bet is to make my own wiring harness for the hatch and just replace all the wiring. Thoughts?
