In the process of installing MT upper & lower links. Checked drive line angles and my pinion is 4 degrees too high & needs to be adjusted downward. I shortened the Upper link to its limit (only about 5mm.) With 2 ratchet straps I still not able to get the rear upper link hole to line up. After reading here, going to try jacking it up tomorrow. Is there any pinion adjustment to be had from the lower link?
