- Thread starter
- #101
M19 bolts look hard to find anyone know of a source? I’ve checked Fastenal and Bolt Depot. 3/4” is probably OK but I get hung up on keeping things metric.
Hey @Turbo, I was looking at your shock mount relo bracket and thought it was essentially using the holes above the mounting pin as the relocated shock eye center but see that your bracket offsets that a bit.I’m thinking now is the time to figure out raising the mount. There are already two promising looking holes in the mounting bracket.
If this works it would add a nice amount of more droop and I could cut off the bottoms of the bracket for more clearance. I need to make sure the shock won’t bottom out and potentially extend brake lines and breather tube. Anything else I need to check?
Yeah, my spacer moves the shock mount up and inboard to keep the bushing in a more oem position.Hey @Turbo, I was looking at your shock mount relo bracket and thought it was essentially using the holes above the mounting pin as the relocated shock eye center but see that your bracket offsets that a bit.
If I just through bolt my BP51 shocks through those higher holes, the change in angle will cause the upper mount bushings to be compressed at a different angle than the OEM setup but will that really cause an issue? The angle changes as the axle goes up and down. Did you design your bracket to maintain the angle or to make it a bolt on mod not requiring enlarging the stock holes to accommodate a 3/4” bolt?
So this is my plan. I've seen a couple post about enlarging the upper hole to accept a proper sized bole for the shock, welding it in properly the cutting the lower mount off.I’m thinking now is the time to figure out raising the mount. There are already two promising looking holes in the mounting bracket.
Do you think the bent shock mount and enlarged upper hole was from the Swell?So this is my plan. I've seen a couple post about enlarging the upper hole to accept a proper sized bole for the shock, welding it in properly the cutting the lower mount off.
I've put in Perry parts extended bumps in and have checked, looks like they will work perfectly for that second hole. I also have metal tech LCAs and they give extra movement in the axle
Springs stay in, will probably add a redundant retainer though. And yeah diff/brake lines are on the parts table just haven't done it. I'm on dobinsons mrr and after a through compression test at uwharrie I'll have about 1/2 gap before bottom outDo you think the bent shock mount and enlarged upper hole was from the Swell?
Make sure the rear springs, mainly the drivers side, won’t fall out at full droop. Also expect to extend the diff breather hose and the brake lines… not that I’ve done this, but I did look into it. Of course make sure shock doesn’t bottom out - remember the PP bumps are progressive so there likely will be more travel than just sitting on them without springs installed.
I’m looking forward to following along and eventually doing something similar one of these days…
The bent mounting pin didn’t happen in the Swell. It was all bent before.Do you think the bent shock mount and enlarged upper hole was from the Swell?
Awesome! That’s essentially what I had in mind but with the bolt flipped around so the nut is on the back side to protect it.View attachment 4139055View attachment 4139056
Here’s a couple photos I found of the 3/4” bolt we used and a small sleeve of steel tubing welded to a small square of plate to space out the lower shock from the support. Seems to have worked fine and is still the same. I like the idea of cutting off the bottom of my lower shock support too but I just can’t bring myself to do it.
Hope this helps if this is the route you take.
I also have LX600 shocks sitting on the shelf to eventually try seeing if they could even mount in this same location and give just a little more droop.
If you have 2” of shaft today and shrink the shaft by 1.2” then I’d agree you won’t bottom out.So took some measurements and scratched my head a bit with some trigonometry and think I’m ok from in a max compression scenario. Someone please correct me if I’m not thinking correctly here but if I was OK before, and my bump stops bottomed out before my shocks, raising the lower mounting point is irrelevant, I’m still ok. From the suspension’s point of view, all I’m doing by raising the bottom mount height is compressing the shock to some other point within its travel limits. The bump stops don’t care where the shockers are or the axle was at normal ride height. It still stops the axle before the shock bottoms out.
So really, all I’ve done with measurements and math is confirm that my current setup is OK with shock travel in max compression. The bottom line is my shock’s max compressed length is 16.5” and the bump stops limit compression to 17.3” so I’m good. Raising the mount doesn’t affect his number.
For posterity (and in case someone is interested enough to check my logic and math) here are my measurements and calcs:
(I did confirm AI’s answer to my shock travel query with actual measurements).
Good points. I suppose rate of movement is a factor. I’m convinced I have enough total travel to be ok as long as the shock can keep up. I’d think the design pressure would account for that though and seals would be ok. With the mount moved up, I guess I’m hitting each bump with the shock higher in its travel. I’m not sure how that would matter. The shock still sees the same extreme. Anyway, I’m not sure what else to do to check it.If you have 2” of shaft today and shrink the shaft by 1.2” then I’d agree you won’t bottom out.
A separate question though - does ARB leave that 2” for a reason? Your shock is pressurized and is that 2” essentially the oil capacity? By dropping to 0.8” remaining are you doubling the pressure on the oil and risking blowing out a seal?
The way your shaft bent I’m still not convinced it didn’t effectively bottom out (being unable to compress fast enough), even if it didn’t actually bottom out. But I know very little
Check were the ride zone turns into the bump zone in the BP51s. I don't think you will want to be driving around when it is in the bump zone.
From the marks on the chrome shaft, it looks like I’m using 6.5” of the theoretical max of 8.6”.Any chance you can look at your current shock and see how much of the shaft is "clean" versus dirty?
The extent of the clean shaft would be a good indication of how much the shock compresses, assuming you have flexed the rig recently.
If there is x" of dirty (non-cycled) shaft and you are raising the shock mount less than that dimension, you should be good.
The shock should not care where in the travel the truck normally rides as long as you don't have bypass shocks. As long as the shock is not hitting the ends of its travel.
I’m confused (which is pretty easy for me). I’m thinking about raising the lower attachment point, not making it lower. The thing that isn’t getting through my skull is that, I think the bump stops currently prevent the shocks from ever getting to the theoretical max compression point. The marks on the shafts imply I am only using 6.5” of the available 8.6” of travel. If that is true, I don’t understand what difference it makes where the shock starts within its available travel.Unless you're saying you have more than enough compressed margin for the new lower mounting point, yes it does matter.
Almost 99% sure you'll need to lower the bump limiter.
