Here is a quick install of the TT guards. Pretty much a 2 banana job since you need to drill a couple holes.
This is what you get:
A pair of the guards in raw. (I painted mine with some Rustoleum.)
Hardware (2 bolts, 2 nuts, 4 washers and, thoughtfully, a drill bit)
Because you will need to drill a hole on the inside of the lower shock mount, start by removing the lower bolts in both sway bar links (14mm) and swing the bar down out of the way.
Then remove the lower shock bolt (17mm). You do not need to remove the shock.
Put the correct guard in place. Either will fit over the lower mount but they are left and right so be sure to pick the correct one before drilling.
Now put you lower shock bolt back in to hold the guard in its proper location.
I dimpled the inside of the shock mount and drilled a pilot hole then drilled the larger hole for the supplied bolt. There is already a hole on the outside of the mount and it aligns with the guard.
Install the bolt with a supplied washer under the head and one under the nylon lock nut. Tighten (⁵/8 or 16mm).
Repeat on the other side.
Put your sway bar hardware back in. Anti seize is a good idea.
That's it. Pretty easy. I took the wheel off one side but did the other with the wheel on.
We will see how they hold up at GSMTR.
