Rear Passenger Door Lock Issues
Charlotte, NC
The rear passenger door on my 96 cruiser will not lock and unlock with the buttons. it will work it if move the switch with my hand. All of my other doors work fine. Ay idea what may be causing this and how to fix?
Thanks for any help!!
Dead actuator is pretty common.
Our right rear door's is intermittent.
It will sometimes not lock when the rest of the doors do, but the alarm sets. Scared the bejeezus out of my wife recently on vacation when she opened it and the alarm went off while I was still in the gas station bathroom. I assume the actuator just needs cleaning or some lube? Or should I just get the new actuator if I'm going to open it up anyway?
OK...dumb question...would the passenger side be considered the right of the vehicle? Trying to make sure I order the right part!
If you are driving a left-hand drive USA 80 series, then yes, the passenger side is the RIGHT side of the vehicle.
The "side" is ALWAYS determined as if you are sitting in the driver's seat, facing forward. So, the term "Left and Right" are the same for both LHD and RHD, but the term "Passenger and Driver" are different.
Rear Right, USA passenger side, AISIN DLT089, Rear Left, USA driver side, AISIN DLT088, also fits the rear hatch.
Landonridge, I did replace both my rear door ones recently, I didn't do too much picture taking as the youtube below gives a lot more detail. Reach out to the Charlotte crew if you need help too.
After watching the video, disassembly, inspection, and cleaning may get the old parts working again. Will give that a try.
With the accurate guidance, it was a relaxing hour to fix this irritating issue. Found this when I got the little motor apart.
2014789
Yeeech. This was inside the motor endcap.
2014793
Cleaned it up and it looked much better.
2014797
I use CRC 26-2 for cleaning and protecting on my model railroad after a rec from a fellow who worked on submarines. It cuts right through crud like this.
2014806
This seems to have been causing my intermittent actuation failures. The video does a great job of explaining things so you can also get those locks working again.
I tried to clean and replace the motor with a new motor from Amazon, I tested it and it worked. Then it stopped working the next day and didn't work again until I bought a complete new actuator from Rock auto and replaced the whole unit.
I did the same, clean and regrease the first time. Lasted a few more months. I got he actuators from Amazon, they where on sale under $30 each for a little while when the system alerted me to the "price drop".
Now, I recommend if you are going through the trouble of removing the door panels, plastic, etc, that it is a good chance to clean and grease the window hardware, that made a huge difference in rear window operation. One of those "while you are in there..."
Thanks for all your reply! I got the new actuator installed but i broke one of the plastic clips that holds the metal rods to the outside door handle. Is there a way/place to purchase these clips?
You can buy the little RC motor for like 6 bucks on Amazon. If you're going in there anyway you might as well replace it. Details here
