Rear Main "while I'm in there"
Fayetteville, AR
I just bought a 97 LC this past weekend. I noticed it was leaking quite a bit of oil so I took it to a trusted mechanic (I do most of my work but time is just not there at the moment and it's a DD). I told him i just wanted it checked over for obvious needed mechanical interventions and I wanted to stop the oil leak. His diagnoses was the following:
- Power steering pump needs to be replaced and a lot of the "oil" was in fact PS fluid
- A rather large leak in the rear main seal
- A few of the coolant hoses needed replacing asap
- AC not working properly due to some seal failures in the compressor
For all the work done parts and labor he quoted $1300 out the door. I know most of that is labor for the rear main considering he's having to drop the transmission.
My question is there anything else I should have him replace while he's got the tranny dropped? Stuff that would pretty much be parts only expense? So far, through the search option, I've found the following:
-Pan arch seal
-rear main bearing
-front trans seal
-oil pan gasket (does the oil pan have to be dropped?)
Thanks,
Travis
IIRC, both upper and lower oil pans come off without pulling the transmission. I would do the valve cover gasket, oil pump seal, and front crank seal first, then clean it all up good and see if the pans are really leaking that much.
-Pan arch seal
-rear main bearing
-front trans seal
Thanks,
Travis
How many miles and do you have any service records?
Odds are it's not the rear main seal. Do the slew of other oil leaks first. You may find you don;t have a rear main seal leak.
Listen to @inkpot he knows his stuff.
+1 to that.
And from memory yes - the pans both come off without disconnect of the trans, however you do need to support the motor to do the upper pan removal.
While some of 'those coolant hoses' are being done, make sure the PHH is one.
And it would prob be worth to swap a heater valve now & just fit up hoses to it on the bench, install in bigger sections.
:::Edit -- if either motor mount is overly bathed in oil, might want to swap if you're hearing any 'thunk' sounds - we all have 2 decade old mounts now, I have it on my list of items to evil eye next time I go take a nap under the 80. /Edit:::
Do the power steering pump yourself , hardest part is pulling the gear, also change the hp line to it at least if not both, pop the inspection cvr and with mirror and flash light look and see if it is indeed the rear main or the pan arch,
If you're doing the rear main, be sure to re-seal the pan 'arch' area by removing the rear main carrier and re-sealing between the carrier and the oil pan. to be honest, it's a pain the @ss to do this way.
Also, before we all throw a ton of ideas that overwhelm you, how about letting us in on weither or not you plan to do any wrenching yourself.
I'd do like 1/4 - 1/3 the stuff I do myself if I was just cutting checks.
Thankfully (now, didn't see it then) -Dad had me stand & watch & hand wrenches since I was old enough to be plunked on a barstool next to the car.
If you're cutting checks & no time/desire to wrench, it's cool --- but since most of us fall far from 'idependantly wealthy', we may suggest a more conservative program.
Are you planning to DL or buy a paper FSM/EWD & learn or already have tools & do some of this yourself?
Are you new to the 'Yota 4wd game or are you like alot of us who cut teeth on a mini-truck, T4R, etc.?
I'd add the distributor seal.
I'll be doing some of the work myself. I've always done little things like plugs, oil, transfer/differential fluids myself. I just got the FSM in a few days ago. I've got the tools to do 90% of the work. I do not have a lift or anything to help with trans/engine removal. I'm willing to take on most jobs when time allows it. This will be my daily driver eventually so it will be hard for me to work on it for extended periods of time. I have a mechanic for things I'm not willing to tackle (rear main is one of those things) that I trust. He told me the rear main is not a must fix just make sure to keep an eye on the oil level.
He quoted me $600 for the rear main in parts and labor which sounded pretty fair compared to some of the other threads I read.
I just got quoted $1100 for the rear main seal and pan arch seal so that seems pretty close. This shop was about half of what the dealership wanted. Does anybody know the part numbers to do both of these jobs? I know a big part of it is the FIPG, I just didn't know about the rest.
FWIW, I had a rear main that I allowed to leak for about ten years before I fixed it. The bottom of the seal is well above the sump; you really can't run the engine dry unless: 1) you're seal really squirts oil and 2) you drive uphill constantly. The worst I ever saw was a quart low. The dual benefits were: 1) there is no rust whatsoever under my truck and 2) I never thought about changing the oil. Well, OK I thought about it, but I didn't do it, at least not too often. When I finally got around to fixing it, I checked the pan and it was fairly clean. Of course, I wasn't traversing the Gobi on a regular basis, but still...
Check with @beno for the parts
Replace the upper/forward hard lines for the rear heater. They are only reachable with the transmission out. You can replace the rear/lower hard lines while you're at it but those you can do with the transmission in.
I've got some oil residue near the rear main seal with some drops of oil on the garage floor so I'd like to get everything buttoned up to bone dry.
Do you guys have Toyota part #s handy for the list below so I can go ahead and order them?
Oil pump seal
Front Main Seal (is this the front crank seal?)
Distributor O-Ring
Valve cover gasket
Upper pan arch seal
Distributor seal
Rear main seal (gonna do this later at Toyota dealership)
Upper/forward hard lines for the rear heater
Rear/lower hard lines for the rear heater
I want to do the rear main seal last as the shop I'm going to doesn't have the equipment to remove the transmission.
Thanks!
Wouldn't worry about the rear main seal and oil pan stuff.... My truck rear main seal been leaking when I bought it with 118k miles, and now at 266k miles the leak isn't noticeable between 5k mile oil changes...
Distributor shaft seal
Oil pump seal
Oil level sensor seal
Front crank seal
Valve cover seal (wires, plugs)
Coolant hoses
Rebuild Power Steering pump with bearing
All the above can be done in a day or a weekend.
So does anyone have OEM part #s handy here?
Oil pump seal 15188-66020
Front Main Seal (is this the front crank seal) - 90311-52013 DISCONTINUED
Distributor O-Ring 90099-14118
Valve cover gasket 11213-66021
Valve - Wires/plugs ?????????
Upper pan arch seal ?????????
Distributor seal ?????????
Rear main seal (gonna do this later at Toyota dealership) 90311-99009
Upper/forward hard lines for the rear heater ??????
Rear/lower hard lines for the rear heater ????????
More than what you asked for but most of it has got to be in there. This is from my maint log on my 200k mile "I'm all in now, make it run forever" trip to the dealership. Wallet was a lot lighter when I drove away but not a single drip on the driveway!
  • Toyota Genuine Parts 90915-YZZD3 Oil Filter, TOYOTA OEM Gasket 90430-12031, Genuine OEM 5W20 Toyota Synthetic Engine Motor Oil 00279-1Qt20
  • tire rotation
  • automatic transmission fluid change - Toyota Lexus Truck 4runner Transmission Drain Plug Gasket Genuine Part 35178-30010, Toyota Genuine Fluid 00718ATF00 Dexron III Transmission Fluid
  • complete brake fluid replacement incl brake service
  • Induction and engine decarbonization service - complete cleaning of the throttle valve and upper intake. Remove depsosits from piston crown, stabilize compression
  • rear differential service - new fluid 75W90 syn gear oil and 90430-A0003 gasket??
  • front differential service - new fluid 75W90 and Toyota Oil Drain Plug Crushable Steel Gaskets OEM 12157-10010
  • power steering fluid exchange
  • complete cooling system service and fluid exchange - Toyoya 00272-1LLAC-01 ANTIFREEZE GALLON W
  • Genuine Toyota 90982-05035 Battery Terminal Assembly
  • Genuine Toyota (90982-06059) Battery Terminal Assembly
  • transfer case service - new fluid 75W90 and Toyota Oil Drain Plug Crushable Steel Gaskets OEM 12157-10010
  • Genuine Toyota (11213-66021) Valve Cover Gasket QTY 1
  • Toyota Genuine Parts 90919-01176 Spark Plug QTY 6
  • Toyota 90099-14118, Distributor O-Ring QTY 1
  • Toyota 90919-21557, Spark Plug Wire Set QTY 1
  • Toyota 19101-66010 Distributor Cap QTY 1
  • Toyota 19102-61240 Distributor Rotor QTY 1
  • Lexus 22271-66010, Fuel Injection Throttle Body Mounting Gasket QTY 1
  • Toyota 15188-66020, Engine Oil Pump Gasket QTY 1
  • Genuine Toyota 90311-52022 Type-T Engine Crankshaft Oil Seal QTY 1
  • Genuine Toyota Fluid 00295-00103 Formed-in-Place Oil Pan Gasket QTY 1
  • TZK 9034112012 Engine Oil Drain Plug QTY 1
  • Genuine Toyota - Oil Drain Plug Gaskets - 90430-12031 QTY 1
  • Toyota 90301-29006, Engine Coolant Pipe O-Ring QTY 3
  • Toyota 16119-66020, Engine Coolant Outlet Gasket QTY 1
  • Toyota Part No.: 13552-66010 Gasket for Chain Tensioner QTY 1
  • Toyota 90919-05041 Engine Crankshaft Position Sensor QTY 1
  • Toyota 13506-66010 Engine Timing Chain QTY 1
  • Toyota 13523-66020 Engine Timing Camshaft Sprocket QTY 1
  • Toyota 13521-66020 Engine Timing Crankshaft Sprocket QTY 1
  • Toyota 13559-66011 Engine Timing Chain Guide QTY 1
  • Toyota 13561-66010 Engine Timing Chain Guide QTY 1
  • Toyota 13540-66011 Engine Timing Chain Tensioner QTY 1
  • Toyota 96721-19010, Engine Oil Dipstick Tube Seal QTY 1
  • Toyota 11328-66020 Timing Gear Chain Cover Gasket QTY 1
  • Toyota Part No.: 96761-24042 RING, O QTY 1
  • Toyota Part No.: 96761-24022 RING, O For oil Pump QTY 1
  • Lexus 16271-66020, Engine Water Pump Gasket QTY 1
  • Genuine Toyota 11193-15010 Spark Plug Gasket QTY 6
  • Toyota 16571-66030 Radiator Hose No. 1 QTY 1
  • Toyota 16572-66021 Radiator Hose No. 2 QTY 1
  • Toyota Part No.: 16573-66010 Hose, Radiator No. 3 QTY 1
  • Toyota Part No.: 90467-43002 Clip, Radiator Hose No. 2 QTY 2
  • Toyota Part No.: 90466-41008 Clip, Radiator Hose, NO.1 QTY 4
  • Toyota 90916-03117, Engine Coolant Thermostat QTY 1
  • Toyota Part No.: 16346-66020 Gasket, Thermostat QTY 1
  • tire rotation
This is great stuff. Thanks for putting this together.
I'm gonna study this thread
Screws qty 7 15183-66020
Oil cooler gasket 15785-66010
  • tire rotation
There are parts missing from your list v. mine and vice versa.
