Try some Barr's rear main seal leak stopper for a while and see if that helps...
Toyota Genuine Parts 90919-01176 Spark Plug QTY 6
Toyota 90919-21557, Spark Plug Wire Set QTY 1
Genuine Toyota 11193-15010 Spark Plug Gasket QTY 6
Oil pump seal 15188-66020
Genuine Toyota 90311-52022 Type-T Engine Crankshaft Oil Seal QTY 1
Genuine Toyota Fluid 00295-00103 Formed-in-Place Oil Pan Gasket QTY 1
Toyota Part No.: 96761-24022 RING, O For oil Pump QTY 1
Toyota Part No.: 13552-66010 Gasket for Chain Tensioner QTY 1
Toyota 11328-66020 Timing Gear Chain Cover Gasket QTY 1
Toyota Part No.: 96761-24042 RING, O QTY 1
Distributor O-Ring 90099-14118
Valve cover gasket 11213-66021
Screws qty 7 15183-66020
Oil cooler gasket 15785-66010
Front Main Seal (is this the front crank seal) - 90311-52013 DISCONTINUED
Upper pan arch seal ?????????
Distributor seal ?????????
Upper/forward hard lines for the rear heater ??????
Rear/lower hard lines for the rear heater ????????
I was able to find a Toyota Forklift Seal that had the very same part # (90311-52013) here:
TruPar . . . Toyota 90311-52013 Oil Seal Forklift Parts :TruPar.com
$25 (incl shipping)
Seems pricey, but I ordered it anyway. I hope it's the same seal.
