Rear Main Seal Fun
Peoples Republic of Eastern California (Denver)
I am going to pull my transmission and transfer case to replace the rear main seal seal this spring. I would like to avoid any unknowns like finding out it's best to install a marlin crawler inner axle seal after I rebuilt the knuckles last year and had to tear into them again after they leaked.
So, is there any advice since all of the seals on the transfer case and tranny are accessible? Or any other things I can do while all this stuff is out?
Definitely use genuine Toyota parts.I just finished this job,well actually I did it twice.Although I read numerous posts saying that it would be wise to replace the 2 expansion plugs behind the bell housing,but because it would have been an extra hour of work to unbolt the bellhousing and rear motor mounts,I figured I was special and mine were probably good to go.Got it all back together,interior and all just to find a small leak when I went for a ride.After a second teardown,sure enough the cam expansion plug had a crack in it.Got my seals and gaskets from Kurt@ CruiserOutfitters and the cam plugs from the dealer.I could have saved myself alot of work and frustration by taking advise better.I did the rear seal,oil pan gasket,cam plug,new clutch,TO bearing and pilot bearing while I was in there.Good Luck!
Definetly replace the two expansion plugs like sawtooth suggested. Mine went after replacing thw rear main and had put it all back together. I would leavethe tcase alone unless it is leaking already. My two cents
Also, you might as well replace the front (input shaft) seal on the transmission while it is off and so easy to do. Now is also a good time to replace the oil pan gasket because most of them of any age leak and because taking off the oil pan will make replacing the rear main seal a breeze with no seal puller or driver needed.
Can you replace the rear main without pulling the bell housing??
Yes. (adding more than five characters so that I can post this answer :rolleyes: )
Real timer help!! Don't mean to hijack.
How? :confused: You still have to remove the clutch and flywheel to get to the rear main. I suppose you could unbolt them, slide them to the side of the bell housing and work around them. But, why make life miserable? A few more bolts and the bell housing is off.
:cheers:
If you are gonna that far and replace the rear main, then x2 on the input shaft seal. What about your pilot bearing and clutch? Are they original or new. Might need to resurface the flywheel if it's got alot of meat on it still. There's a write up on mud somewhere about the rear main. I used the black pvc pipe trick, it's the same diameter as the seal. Really helped the process of replacing it.
:cheers:
he didn't ask the easiest way to do it, or how to do it correctly, and obviously he couldn't be bothered to look in any service manual or search any one of the 1,000 previous threads - he just asked if it was possible. :meh:
:cheers:
Yes, you can, quite easily. Removing the bell housing is a good idea if the engine is out of the car, but it probably won't be. So ... Remove transmission and transfer. Remove clutch and flywheel (Both of these drop out the bottom of the bell housing). Drop oil pan. Remove rear main bearing cap. Replace seal with only your hands as tools. Put it all back together. All of which can be found, with pictures, had anyone bothered to search.
Good stuff, getting my newer TC ready to go in and at the same time doing the clutch and seals...and now I suppose the expansion plugs also ;)
Getting ready to do this job. Trying to find part#s. I have the rear main already and one of the cam plugs.
Looking for input shaft seal, TO bearing and Pilot bearing part# if anyone has them.
bTW-Oil pan gasket is already done.
When I did mine, the new pilot bearing and TO bearing came with the clutch and pressure plate.
Thanks.
Anyone know the trans input seal part#?
SOR has these parts in stock. I got mine from them. No muss, no fuss. They'll FedEx 'em, even to BFE.
thanks but for <$10 and a PITA job, I'll go with the Mr T part.
I believe the correct part# is
Ref: 90311-28004
