Rear driveline problems
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Well I'm now down to crunch time getting the cruizer going for the 1000 mile adventure to the beach. I'm in need of a new longer driveshaft (the yoke is shot). But I think it may be only a part of my problem.
When The drivetrain is underload (accel or decell) everything is fine. But when I'm in that area where there is no load but I'm over say 25 mph I get a vibration. I can hear it more than I can feel it. And it only does it when not under load. When I inspected thee driveshaft I noticed the yoke had slop in it but I also noticed that I could move the driveshaft back and forth about a half an inch before the rearend would engage. Does this sound like a pinion gear issue. How hard is it to realign so I can get rid of this slop?
Man that's a tough one. Exactly where is this fore and aft play you mention? In the parking brake drum or the pinion itself? The slip joint will have a minimal amount of play but anything excessive would need to be replaced. There are plent of folks with used driveshafts that you could use as a spine donor or even possibly replace your entirely if it's in better shape. Something is seriously wrong in your third member if you have 1/2" play in the pinion. The only way I could see this happening is if either the nut came off the pinion flange or if the pinion bearings have disinegrated which is unlikely as this would surely show up in unavoidable catastrpoic failure.
The history on this rear end is not good. The PO had a anti wrap bar installed incorrectly and it ended up wrapping around the axle taking out the entire rear end. When I got it the outputshaft bearings were shot from the carnage along with the driveshaft which I just found out.
I'm just going to play it safe and replace the transfercase (which this will be my third) Because the rear output shaft high gear has some play in it.
The driveshaft cause the yoke is bad and it's to short from SOA with Hyper shackles.
And the third member because I think something is up with the pinion. I'll know more about it once I get the driveshaft off.
Nolen is hooking me up.
At least now I'll have some trail/road spares just in cases.
I'm going to strap the camcorder to the underside tonight and get some video and sound maybe that will help me figure out what is going on.
When you say "rear output shaft high gear" do you mean there is lateral play in the TC rear output shaft that shows up as play in the parking brake drum? If so you can correct this with shims that go inside the speedo gear housing to set prelaod on the rear output shaft bearing. I have bunch of these and could send you several...they were like $1 each from Toyoya. I'd love to see some pictures of this wrapped antiwrap bar. Musta putta wammo on it.
see the link item 33
http://tinyurl.com/8f8x9
Nope it's actual play aka wobble on the high gear on the output shaft.
Gear on right.
This kind of vibration is often associated with a worn slip yoke on the driveshaft or a shaft where the spline engagement is too short, so it could be related to the fact that you need alonger DS.
What do you mean wobble? Rotational play on the shaft or the bushing is worn out so that the gear tilts on the shaft?
i have the same exat issue with my shaft.. no play that i can feel.. 3rd is welded.. Only started this after i had the shaft retubed in moab when i twisted it up..
Ohmygod! Carnage! You left that little part about the bolt exploding through the side of the case. Sounds like a new to you TC and rebuild are in your short plans. get a d-shaft too or lengthen yours if splines are OK
actually this is my original case which I had just done a great rebuild on and everything was perfect. Except for that bolt! The case I have now I bought thinking I could use the whole thing except for the bearings and idler shaft.. Wrong!
It had these problems that I didn't see upon further inspection.
And I had this done to it to get me by until.
So I had to use my original Transfer case parts that had just blended up that bolt in the transfercase I had just had welded because it had carnage inside as well as out. problem when I got it back together the high output gear was out of tollerance and you could tilt it to one side. I knew it would eventually give me problems down the road.
And this is probably what screwed up my driveshaft.
http://home.ripway.com/2005-5/300909/Marshallsclimbmovie.wmv
What you cannot see is the driveshaft hitting the rocks. And the driveshaft is to short.
