My passenger side rear door never seems to lock or unlock on the first try. It almost always does on the second try. Is there anything that can be done to help this (fresh grease, etc.) or do I need a new lock actuator?
If a new actuator is required, does anyone have the Toyota part # or installation tips? I've had the door panel off, but didn't spot the actuator in my quick examination. Of course it worked perfectly while I was checking it.
I have this problem with both the keyfob and the power lock/unlock switches on the front doors. It seems to be isolated to the actuator on this passenger rear door.
I've discovered that my TIS repair manual download was not complete, so if there is a page that shows any detail on this that someone could post, fax, or email me until I re-download I would be forever grateful.
Thanks,
-Tim
Thanks,
-Tim
job now that I know what I'm doing. Be sure to put the moisture barrier back properly when reassembling to prevent issues down the road. Patience when removing and re-installing the mechanisms is required. After that perform step #6 cause you're home free...
