Rear differential
Question...is it normal to have some play in the rear diff? When jack up I can rotate one wheel and feel about 1/2 in of slop. Also, when deceleration the diff whines. It sounds normal during acceleration. So, is this normal or do I have bearing issues or pinion issues?
mine has a little play but it dont whine, my front one does what your rear does but its more of a grinding sound when i decelerate. i cant figure it out
Mine was doing the same thing...the pinion nut had come loose...I tightened it back up...loose again in less than a month...so now I just loc-tighted temporarily to see if that helps...after that...it's a rebuild on that bearing...
and of course a locker :D
The noise on decelleration is likely a pinion bearing going bad. Some slop aka backlash is normal but it's a very small amount. I would plan/budget for a diff rebuild.
The pinion nut should be a 'stake' type nut....after it is tourqued, there is a spot in the pinion to drive a punch into the side of the nut and seat this area of the nut into the machined groove of the pinion. I still use red locktite on these, in conjunction with the stake nut.
If the pinion bearings have been taken out by the pinion nut not being tight, I would seriously question reusing the carrier bearings because of the metal that would have been in the gear oil...and, depending on how long this condition has been alowed to exist, the alxe bearings could be inspected also...
Just my kanadian .02... ;)
Good luck!
-Steve
