Rear Camera Hook up (HELP)
Gilbert, AZ
Ok so my 80 is gutted no interior. I Ran the rear camera to stereo. I need a power sours for the camera. I hooked it into the License Plate lights. I still have no image but followed another thread for the Reverse lights in drivers side Kick panel. I may have hooked power to wrong wire in the lights. Can someone tell me wires in rear gate for License plate light which wire is the positive?
That is all thanks
Don't have an answer to your question, but can you post up details on the back up camera system you're using?
Do you have a test light or a multi-tester? With a test light, all you have to do is probe the connector while the lights are on and you'll easily identify which wire is positive. I hooked mine up to the back-up light so it comes on every time I go on reverse. Good luck.
I used a multimeter normally i use a test light but must have mixed them up I think i need to flip flop. I did a rockstar install looks like a million bucks will have to undo everything and try again.
If you hooked it in with the plate lights, wouldn't it only come on if the lights are on?
^What mikedamaeinc said.
IIRC the stereo AND the reverse camera need to be tapped into your reverse lights. That way, the head unit "knows" you are in reverse, turns the video signal on and your camera powers up. Does that make sense?
AND, it would be on full time with the headlights, regardless of being in Reverse or any other gear. John
regardless of where you hook up the camera there are two wires one has a power and ground. the other goes to the head unit. The head unit has a reverse wire. The camera only turns on when the head unit detects that the vehicle has been placed into reverse.. Pretty sure my problem is at the Positive and Negative wires
i ran the positive wire and the reverse wire to the same leg of the reverse light.
it's a shame my neutral safety switch doesn't work.
My stereo has several settings for the camera polarity. You may want to chk this if you think it is connected correctly. Given how I connected it mine is set to "battery". If this setting is changed I do not get a picture.
...via IH8MUD app
X2 ^. That works perfectly.
Yes your problem is at the pos/neg, it needs either a constant feed, or preferably what Boltripper says above, when the reverse lights are on. The head unit reverse is just a trigger but the camera still won't come on if it doesnt have juice, which would be supplied when the reverse lights are on, or like you stated before would only be if headlights are on and in reverse.
Thread resurrection!!! I'm in the same boat. Can't get my cam to turn on. I tapped into the reverse lights, red wire blue stripe, and am getting 12 volts on my meter when in reverse. Ok there. Tried a few different ground connections. Checked my head unit reverse cam settings all good there. Double checked my connection to the head unit. Any suggestions anyone?
