I'm a truck driver, when the alarm goes off all you have to do is put the transmission in neutral, turn off the ignition and then restart the engine. That resets the alarm and you get another 30secs. You can do that all day long or until the engine blows up.
With the irrigation pumps we used old engines out of cars or pick ups, set the throttle on the carb to the pump speed we needed and locked it there, then we just let them run out of fuel, we did not time them to run. If the irrigation pond wasn't full enough we just put more fuel in the tank and started over. Some of those Murphy switches had timers, like the sleep timer on your tv.
Yes, the UG you can set the alarms to what YOU want, so if you want it to go off at 200*F engine temp it will, then you press a button to silence the alarm.
You can also set exhaust temp alarms, etc. Some alarms only work with certains systems, I have all of my alarms turned off.
Mine is old enough that it will not read trans temp or oil psi. I have the 2nd generation of it. It is so old some of the pixels have dropped out when it gets hot from sitting in the sun all day, like when I'm at work.
