real time brake help please
granger, indiana
I have a 68 FJ40 that I have done mini truck disks on. I used 81 cruiser rotors and 86-88 ifs calipers. The rear drums have remained stock. I used a mini truck master cylinder and booster with a spacer to clear the firewall rib. The master cylinder has only one reservoir and I have the front brakes plumbed to the outlet closest the the firewall and the rears plumbed to the end outlet (furthest from the firewall) I adjusted the rear brakes very tight to get some pedal pressure because it didnot seem to have much. It seemed to help but the pedal goes to the floor and the only thing stopping me seems to be the overly tight rear drums. It feels like the brakes are trying to engage but don't. What could be my problem? Thanks in advance for your help. Tom
I don't know about mini masters, but most of the masters I've seen have the front axle output farthest from the firewall. Opposite of the way you have it.
Can anyone confirm the outputs on mini masters?
good bleeding is needed and a bench bleed of the master is really the only way to start this. I just did some work on my rears and after bleeding a full quart of fluid through, I still didn't have firm pedal. I had to bench bleed the rear circuit of the MC and then bleed the rear brakes again to get it right.
Also, there is an adjustment of the rod that goes from the booster into the master cylinder. Did you adjust this properly?
There is a freeplay adjustment on the brake pedal, but if the booster rod isn't setup right, this won't help.
I think that is because you got some GM info. That is how I have my master plumbed, but it is a '75 corvette 4wdb manual master. Good on your fix.
Ed
cruisertom said:
A friend of mine is a hot rod builder and just in conversation I asked him to double check myself. Well that is what I get. Thanks again I reversed the lines and now it works great.
Ed is right, like many other things, GM got it backwards :flipoff2:
Tom, I made a big fauxpaux when plumbing mine. Set myself up for potential problems by plumbing my rear circuit this way....with the line above the master.
Used a vacuum bleeder because I don't have any friends;) Worked out OK, but the way I did it is a NO-NO.:doh:
Ed
