real steel body parts
no not a tub. just parts. i already have a bunch of stuff from ccot, but i need the rear bed section and can't see paying ccot's 700 price for it.
i have to say the turn around is incredibly fast.
16ga.
the ribs are much more pronounced than oem.
Looking at a 40 with the back in bad shape. Wondering about this panel or just go get a donor pick-up bed and cut the flooring out in it and make a panel... I've done that before but, wondering how you liked this one.
J
i'm completely redoing the back half of mine, from behind the front seats will be all new.
also my first attempt at sheet metal work.
Brian, be patient and spend a little extra time with fit. I like to barely have a gap when welding thin sheet (reduces burn through). Use .023" wire and move around A LOT . It warps easily and heats up quickly to promote burn through if you hang around in an area too long.
Take your time and practice on a scrap piece in the position you need to weld in, get dialed in and go. You'll be fine.
Good luck..
J
four and a couple dollars shipped....way way less than ccot, and it arrived weeks faster than them as well.
