re-tapping threads after paint
South New Jersey
I just painted my inner fenders. My first time, should I tap the threads or will the bolts knock the paint off as I thread them?
Tap them to clean them. If you did primer, base and clear then you need to tap them. I had to or the bolts would bind up before tightening the parts.
try starting the bolts, maybe a few turns. Remove, repeat this several times, and you should have a clean area to put your bolts in. Typically this will work with patients. Just take it slow, don't try that extra turn when you think you can make it.:popcorn:
