Rattle Rattle
The Ghetto
When I am at highway speeds and I coast in neutral or in gear there is a rattle underneath my 72 fj. It sounds like something is loose. Also, when I accelerate it also vibrates. I know this is pretty vague but maybe someone could shed some light here.
Well, by the looks of the PO setup, it has a Rough Country suspension lift (not sure about height) I had issues with throwing the drive shaft this past Friday but the shaft didn't show any visible damage but i'm worried about an unbalanced shaft.
exhaust?
Given you threw the driveshaft, I'd X2 the "out of phase" Bailey mentioned.
:whoops:
Do you know what I mean by driveshaft "phase"? If not, do a search. The grease zircs need to be lined up when you put it together. If it came apart once, it's going to happen again until you get it fixed.
Throwing the shaft?!?
Just what do you mean?
Do a search, look in FAQ to find out what "in phase" means and be sure your rear driveshaft is in phase.
chock wheels, put transfer case in neutral and release the parking brake and check the driveshaft for slop in u-joints and slip joint
buy a magnetic angle finder and check the angle of the t-case flange and pinion flange with respect to level. They should be nearly the same The lift may have thrown this angle off, and it may be necessary to install spring shims to correct this angle. They are available at almost every cruiser vendor and some Napa's.
pull the rear driveshaft and rotate both u-joints on both axis, if there is anything other than smooth, easy rotation the joint should be replaced with a toyota joint.
having proper u-joint angles, and an in-phase driveshaft goes much further towards a smooth driveline than a balanced shaft.
