Give me some straight talk about the 40 I may be buying....
Its a 74 with a 283 sbc V8 mated up to a Turbo 350 Auto and 3.70 diffs. Has a 4 inch confer lift, Power steering, new black rock crawlers with 32x11.5 BFG AT (brand new) and kayline rear tire and tank carrier. Paint is rough but the body is in good shape. No body rot and very little surface rust. Floor boards look great and no dents--just tons of chips and faded paint. Hard top in good shape and all the glass looks great and has new seals.
Its got this funky dual exhaust that exits just behind the doors on BOTH sides its routed outside the rails. The tranny worked well but the linkage sucked and would need replaced. Its got a 6pt roll bar and nice deck with cheap speaker boxes. The frame is very clean and straight.
On test drive: Brakes suck ass and will need a front disc conversion immediately! Surprisingly less power than my 350 in the 55. Its got a 2 barrel carb--can that be swapped for a 4 barrel and get more hp? Engine started right up and purred nicely.
Big grind with the tanny in N when locking in the t-case (is that concerning or normal?)
Electrical is funky. The lights work but turn signals are shorted. Guy has everything split up since he couldn't figure out the short. Toggle switches activate the radio feed, dash feed and electric fan. Dude just spent $1200 on drive line rebuild and $900 on tires and wheels.
I'm not looking for the perfect cruiser...in fact a bit of a project is desired
What do you think its worth in Nor Cal area. He is asking $6200
