rancho shocks
Hi all I have rancho adjustable shocks on my 80 series and am tempted by the in cab kit, does any one recommend it.
regards rob
Sounds like a pain in the ass to mess with. Adjust them to your liking and leave em alone. I used to use 9000's and never condisered the in-cab adjustment. Your opinion is the decision maker though.
your first problem is buying shocks that do not self-adjust (i.e. velocity sensitive), but now that you've dropped the big bucks, here's the deal:
(a) You need very durable valving on the front-end, manually set the front shocks on a moderate to firm setting.
(b) You need ultra soft valving on the rear-end, manually set your rear shocks on the softest setting possible.
(c) Forget the plumbing kit because they leak anyway.
(d) Beat the dickens out of the Ranchos, then get some Bilsteins.
Jeff,
I doubt you can.... or I haven't heard it being done anyway!
I have the Rancho 9000's and I've just set the dial on one setting and left it there. I've been happy with that and have had no desire to mess with it.
Good luck!
Mot
Jeff,
Good luck!
Mot
I'd never get around or bother doing it, it was just a weird idea banging around in my 'noggin.
I have the old stype 9000's on mine, they are permanently set to whatever they are at, on a couple anyways, as a rock or some other large object cleaved off the dial.
Having gone the Rancho to Bilstein route on my FJ60, I have to agree with this. The Bilsteins are a far better shock, they are both more comfortable and more controlled. Kind of a strange paradox, but they get it.
Thanks for all the replies I recon my main concern is that I can have a much softer ride when of road as some of the terrain on our trails can go from deep muddy ruts to rocky road, one of the reasons I asked the question is would the air lines to the shocks hold up when fording deep water? :cheers:
I had 9000s in my 80 4 several years and liked the ability to change them depending on road, load (Camping) or 4x4ing. I'd consider an in-cab as well as lying underneath can be tiresome.
Consider adding extra protection (Aussie boys get these as optional 4 Rancho shocks) where the dial is at the bottom as they can get banged up pretty quickly. I'd expect u'd have 2 be careful 4 similiar protection if u are going 2 run air lines
I have the in cab controls, I use them every morning as they leak, actually i adjust the every hour or two on the highway as they leak this much. The other thing is i dont notice that much difference between soft-hardest. One day when i have the other problems sorted out i will probally go to bilsteins or fox shocks.
In other words, do yourself a favor and dont invest anymore money into these things,
Decision made
I appreciate all the feedback and based on this I have decided to give the in cab kit a miss.
Then concentrate on the next mod running 12 v electrics to the rear for a fridge, also an electrical supply to hook up an army trailer for camping. :cheers:
