Rain and dash cluster
Beaverton, Oregon
Trying to get some input from you guys that have been enjoying their FJ longer than me. Have you guys drove through the rain with top off or accidently left it in the rain. What does it do to your dash cluster or interior for that matter?? Is there a way to water proof them?? What do you guys do??? I live in portland, so rain is pretty much everyday if not almost. Thanks a bunch, ivan:bounce: :cheers: :bounce2:
Works fine for me..
As long as you don't mind the cruiser won't.
Cept for the stereo that is..
bikini top. it does'nt do much when it pours over night.
no problems with any of the oem electric stuff....the PO installed aftermarket radio did'nt fair well though.......something shorted out right after i got it, the damn thing would NOT turn off. i pulled the inline fuse and "fixed" that..then yanked the speakers.....
It only rains once a year in Oregon - September through June.
I took my top off a month too soon, and have to wrap a tarp around it every night and on days when rain is expected.
Some of the gully washers we've been having lately will fill the tarp sag in the roll cage top up with enough water overnight to easily fill a five gallon bucket. That's a lot of water, and I can't help but wonder if it would soak the seats enough that the stuffing would become saturated to the point where it would promote mildew. I can't see it easily drying out when it rains for a week at a time or more.
Driven and left out in the rain many times. No issues. Bikini top does help. Cruiser's have weird aerodynamics. When I drive in the rain with the bikini top on, the rain actually comes forward (from behind the seats into the driver's area).
I also keep a tarp stashed in the rig for both covering up the cruiser and lying under it. Never know when it will come in handy (I live in Oregon too).
No worries. But its a real hassle trying to see in a downpour with water running down the inside of the windshield. What makes it worse is if you wear glasses.
:ban:
Thanks for all you guys' input. I currently have a top and full safari door with some rips. I was thinking to take off the top and be done with it. The rain makes me think that I should keep it. At least for a while, to see how often I actually use it. You guys in Oregen, where are you located at??
drove in the 2 harshest San Diego storms this year - not by choice mind you - and all I have is a mesh bikini. the only thing that suffered were the speakers in the rear. after 2 days, they dried out and worked fine again. the dash and all gauges were totally fine. and, I am talking over 1" rains in like 1 hour in each scenario - major down pours.
Driving the cruiser topless in the thunderstorms here in central Florida gives the other drivers something to laugh at and makes their day, keeps down road rage. Buy a $10 rain suit for yourself and a $1 squeegee for the inside of the windshield, and go on down the road. I have replaced my fuse block once in the past years due to rain, but nothing else seems to mind.
Don't use any floor mats or other things that will hold, or block water from evaporating, or you'll have big rust problems.
Jerry D.
I ususally remove my hard-top in early march, and put it back on just before X-mas. I have no soft top other than a bikini top that I use from time to time. My truck sits outside rain or shine, no tarp nor cover. As long as your seats are vinyl, then it won't harm anything. The worst that happens is my gauges fog up from the inside a little, but they dry in an hour or two, which can be cured by removing them and using just a touch of silicone on them, and o-rings on the round after-market gauges. My ashtray fills up with water, and about every other year, my horn just starts quietly ringing from a buildup of mouisture in between the contacts. Just dry off the seat and fire her up, she'll go.
Hmm, we're up to ~.75" this year for rain. I did end up driving topless in one of the showers and except for forgetting which knob controlled the wipers, the Cruiser was fine.
L
Have you done anything in particular to prevent rust in the tub? Is that even a problem? I'd like to do this, but I've always been too paranoid.
If your tub is painted, with no exposed steel, then you should be fine. I drilled some drain holes in the floor pans, one in the front of each footwell, and one in the back along the door on my 79'. If you provide drainage then you will be fine. My seat belts have held up, as has my dash, seats are great condition vinyl so they never absorb mouisture. I have no carpet to hold moisture. And clean out the accumulated leaves and junk every week. Try it for a week, see where, if anywhere your truck is trapping water and make the corrections to it. Good luck.
