Radiator Replacement
Hillsboro, OR
Preface:
Trying to wrap my head around this, and wanting to try and figure out exactly what I should do (I can't seem to find a guide that I think sums it up).
Story:
So this weekend, I pulled my radiator, it had sprung a leak in one of the fins, was original, and I just wasn't comfortable with it anymore. I've got a replacement on the way, I went with an all aluminum 3 row. I also purchased two gallons of Mr. T red coolant concentrate. My engine was rebuilt <10000 miles ago, and got a new water pump, oil pump, t-stat, belts, etc at that time, so I don't really have much "while I'm in there work".
Question:
This is where I'm confused/need help. I've already got the radiator out of the truck, and want to get all the green coolant out before I install the new radiator and fill it with OEM blood. How do I flush the block and heater cores without the radiator installed? Most/all guides I've found presume you have a normal working setup to begin with, and in my case, I never want this new radiator to see the cheap green stuff.
Bonus points!
If someone in the Portland, metro area also wants to earn a few beers and make a friend, I could probably use the hands and experience (radiator should be here mid-week, looking to have the truck running by the weekend).
Just pull the thermostat out and run a garden hose through the system! Pull out the block drain too.
And that will get the rear heater core, as well? Seems too easy.... How much water will stay in the system after flushing (so I know how much distilled to use at the end), or will it be relatively "dry"
Just connect a 5/8" garden hose to the drivers side of the heater valve. With that valve open, turn on the hose and push the tap water thru and out the top of the radiator. After about 5 minutes of that, your original coolant will be totally diluted and displaced by tap water. Let it all drain out and fill with your favorite flavor of coolant. Some folks think you should do a final rinse with DI water, but I can't see any value to it. In over 50 years of driving and wrenching I have never seen a need to do that. John
Thanks, going to try and get the new radiator installed tonight.
To clarify on all these points:
  1. I've already removed the old radiator
  2. Remove the block drain plug
  3. Flush from thermostat (all directions) until clean/clear
  4. Open heater valve and connect my hose to the driver side of the heater valve and flush until clean/clear
  5. Button everything back up
  6. Fill mix into the top radiator hose, back into the block
  7. Fill radiator with mix
  8. Start engine and ensure rear heater is on
  9. Monitor/fill radiator until system is full
Am I missing anything? I just don't want to mess this up, as I'm changing coolants, and don't want a ton of sludge because I miss something obvious.
Is this for a FJZ80 or FJ80 (3fe)? where did you source the Rad and how much $ ? whats wrong with the green stuff?
Thanks
The green stuff is CDan approved............
Thanks
This is 96 fzj80, I already have the red stuff, bought the concentrate on Amazon a ways back when I first bought the truck for an inevitable cooling system rebuild (that I never got around to).
The radiator, I also sourced from Amazon this past weekend, linked in the original post:
Amazon.com: Primecooling 3 Row Triple Core Aluminum Radiator for Toyota Land Cruiser /Lexus LX450 V8, L6 Engine MT/AT 1990-1998: Automotive
Edit:
I guess replacing the radiator without doing a complete coolant change would be easier, and it was done two years ago when the head was rebuilt, so maybe I'll just pick up some green and make this a much quicker job, and push off the flush until next year or something?
What's the recommended green round these parts? I have an Advance Auto, Napa, AutoZone and Baxters all within 15 minutes...
Personally I'd sell the red and run green since it is easier to find wherever.
The side of the heater valve doesn't matter.. actually I'd try to avoid pulling anything off the heater valve itself due to the potential for breaking the plastic. The rubber heater line where it connects to the hard pipe along the exhaust side of the engine is what I used. Not much chance of breaking anything. make sure the heater valve is open (in-line) and all the flushed water/coolant will run into the head and out the block drain.
... The side of the heater valve doesn't matter..
Depends on what you are trying to do? Hooking it to the passenger side will only force water through the motor, driver side will force it through the heaters, then the motor. If the goal is a full flush, coolant change, best to flush the heaters.
... actually I'd try to avoid pulling anything off the heater valve itself due to the potential for breaking the plastic. ...
If it breaks, call it lucky, better now than on the trail. If the hose(s) come off of it, maybe good, but at this age, best to inspect, most are brittle and need to be replaced. Have had a couple break on the trail, not exactly convenient?
That's a nice radiator. I hope it holds up for you.
I installed one of those prestone flush kit tee's in the heater return hose there above the thermostat, disconnected the upper radiator hose, opened the radiator drain and pulled the block drain plug.
I turned the hose on with the heater valve wide open. This will back flush the heater cores and should provide a thorough flush of the head and block. After several minutes of this, I started the engine and continued to flush another ten minutes or so because mine had a good deal of rust in it.
Once the hose water ran clear, I disconnected the hose and capped the newly installed prestone tee. Due to the fact that the tap water in my area is moderately hard with calcium, I then flushed the system of tap water by dumping 20 gallons of distilled water in the radiator fill port with the engine running, heater valve open, upper hose still disconnected and block drain and radiator drain still open.
This may sound confusing and/or over zealous but my system was very rusty, I had just installed a new radiator and the water at my house being moderately hard, I wanted to make sure I flushed all tap water out.
Some folks may not have hard water issues but I know that the radiator in the rig I had before entering the world of 80's, plugged up with calcium deposits because I always put garden hose water in it.
I had to flush my system because the PO had MIXED green/Red and I had brown sludge.
I flushed with a garden hose shoved into every orifice I could find until it ran clear. Then when my new radiator was in, I filled and drained SIX times with distilled water, with a day's drive in between.
Then I put in Toyota Red (Because CDan was still on the fence......)
My coolant STILL looks like Fruit Punch Gatorade, even after 2-1/2 years.
The direction to flow water and get all the important parts was implied I guess..
And good point about busting the heater valve.
Getting this installed, and realized that the OEM radiator has a small inlet hose next to the main inlet hose. The replacement radiator does not have this small hose (and many pictures I see of others radiators also don't have this hose).
What is it, and what should I do with it? It appears to just meet with the main inlet close to the block.
I'm stinking it's the other part of the #2 water by-pass hose. Sends coolant through the throttle body if that the one I'm stinking of.
Found this with quick search.
I took some photos of the hose I was referring to, and shots of the OEM and replacement radiators for clarity (disconnected hose next to the top radiator hose). I didn't see this house on the radiator parts diagram, just trying to figure out how to proceed.
I don't see it on that diagram either.
I'm away from home or I'd go get pics. However, I still say that hose goes to the throttle body (or from it, whatever).
Can't you just look at your own truck? If your pic went aft 8 more inches.....
I think it connects to a pipe below the TPS.
The second picture shows where it connects, the camera is basically resting on top of the main radiator inlet house, they connect to the same hardline.
