Radiator Replacement
Finally got my radiator, fit was spot on, and everything buttoned up correctly. Of course, nothing goes as expected, and my negative terminal failed when I went to hook up my battery, but a trip to the parts store and 3 dollars fixed that problem!
I recommend putting the top tower mount bolts in the radiator first, then securing it to the bottom mount, otherwise it gets a little difficult to maneuver...
Steve, sorry for being dense here, but I've gotten lost in the sequence of events. *What radiator did you finally decide to go with?*
I just got the 1800 radiator aluminum replacement with plastic tanks (like OEM). Came packaged well, no leaks, and a lifetime warranty. Total came to 174 (I picked it up in store).
A long time ago I had a Ford 550 diesel I chipped it and removed all the emissions BS. After that it ran like a raped ape and did so for about 46k miles until I melted to pistons and blew the head gasket. It always liked to pop the radiator hoses off if I was a bit heavy with the go pedal. That trucks coolant system was far more complex than the 80's is. I bought one of these to remove and fill it and not have to deal with burping it for 3 days to get the bubbles out.
UView 550000 Airlift Coolant Filling Tool
