Radiator Replacement
You can run the Red.
It's technically better, but your splitting hairs if you change every 5 yrs or 100K miles whichever comes 1st.
Spend the $2 on distilled water, as it will be circulating thru your system many millions of times.
Odds are if you have a leak you will have the system drained in short time and will have to fill with what is available (water works if not freezing out) so not having red will not be an issue.
That makes a lot more sense, going to buy the damn CSF radiator, seller didn't even include new transmission line coupler (as indicated). I hate it when descriptions and sellers aren't accurate...
... going to buy the damn CSF radiator, ...
Why? Just removed one, full of solder bloom, not flowing well. Aluminum radiators cool significantly better, it's not like they are rare or expensive, have seen good results from, TYC, Koyo, etc.
That's why I picked that all metal aluminum one, just wish it was the correct fit. Any way to shoe horn it in there before I go through the return process?
Edit:
I guess on further reading on the subject, the mounting is the same, but those hoses are all different. So frustrating, maybe the 1-800-radiator of Portland has them in stock.
@Tools R Us, I didn't realize the CSF was copper.
Edit:
Victory, 1800radiator Portland, will have it in store Monday (I have the day off), got the aluminum core, plastic tank model for 174. Looking forward to just getting this done, it's hard going back to one vehicle for more than a week.
As others have mentioned sell the red stuff and go with green since thats what is already in use. It will save you from potential headaches.
Oh and be sure to pick up a few gallons of distilled water from the grocery store. Flushing with tap water is fine but for the final fill it should be distilled.
Looks like the wrong radiator to me. Amazon says it fits the 80 make model and year, but it sure isn't a plug and play solution that is for sure.
Ok. Does anyone know of a plug and play option for an all-aluminum radiator?
Yeah, I don't recommend it (unless you have a 3fe). It's well built, and solid, welds look good too, it's just not correct for the 1fz, and I'm not willing to modify it and lose the warranty, or wait any longer.
I haven't had good luck finding an all aluminum replacement, except for ebay:
Aluminum radiator for LANDCRUISER 80 SERIES FJ80R FZJ80R 4.2 4.5L 6Cyl 1993-1997 | eBay
I think the "modification" required to fit, is fitting the trans cooler couplers to the radiator.
I just installed Koyo A1918 last week from radiator.com and it already started leaking out of the top seam where the aluminum meets the plastic top. They brought me a replacement and will install soon, hopefully just got a lemon and it doesn't happen with the new one or else I can't really recommend them.
CSF - full of solder bloom......
Koyo - brand new and leaking already.......
The more I read and try to save money on a radiator the louder Beno's voice gets in my head "oem, oem!, OEM, OEM!".
Sucks on your luck with the Koyo though. Seems pretty rare, most people have had great success. Hope your next one is perfect.
Just to add to the thread. I recently replaced my radiator and had a bunch of toyota red/pink from the dealer sitting in jugs. It's been run on green since I long as I had it. I stayed with green in the end. Because:
  • Everyone uses green. It's by far the most common coolant and if you're in a group then you can share with others and they can share with you.
  • The advantages to red/pink are really hard to nail down with any sort of precision, minus a general Toyota elitist attitude of everything Toyota makes is better than anything else. Like we should drive with Toyota gas and Toyota tires too.
I'm not knocking red/pink coolant, but for anyone who's running green, you're in good company. Flushed green, a new radiator, and general maintenance goes a long way.
I have a 94 and got an OEM radiator. 1000 miles later, 200 of which were offroad, it's great.
I had already bought one of these all aluminum radiators from Amazon when I came across this thread, certainly not a plug and play option, but from what I can see, it is a well built radiator and quality seems decent, now I'm debating if I should just return it or bring it to a aluminum fabrication place where they can drill a hole and weld a steam tube connection similar to the OEM.....
What do you guys think about this idea? Are there any other differences between the aluminum radiator and the OEM that have not noticed?
I think this would solve the issue. Your comments will be appreciated.
See if you can return it if you're planning on keeping the truck for a long time. I returned an aftermarket and went OEM. It's really not that much more expensive considering...Radiator - Toyota (16400-66040)
Ooops... I don't know why I had the idea the original toyota radiator had been discontinued, several friends asked why not go OE Toyota and my response has always been that it had been discontinued.... Going to one at 8am tomorrow.... Thanks!!!!
Where are people getting this information that the radiator is discontinued?
Amazing that these box kickers still keep their jobs after blatantly lying to paying customers.
Mind boggling.
Yeah, laziness and ignorance.......
"Well, the computer says it isn't available."
Never mind that they plugged in the wrong year, part number, or information in the first place........
I used to work behind the counter at one of those places LONG ago and I've seen some pretty pathetic attitudes that manage to stay employed and even flourish..... I don'g get it either.
Just buy an OEM. I got one from CDan when he was still working at the counter about 3 years ago.
Also, go Green coolant because it's more readily available in the event that you forget to change out your PHH when you're rebuilding the cooling system, then it decides to fail when you're out on the road and Toyota Red is no longer available........... Hven't had to do it yet, but my time's a comin!
