- Thread starter
- #21
That is taller than Beno.
-Mike-
And in case some of you are not aware of the inside joke here ...
-Mike-
101:1 final low range.
pappy said:101:1 final low range.
That means torque at the wheel is on the order of 10,000 ft-lb! Do you have beefed up axles and shafts?
pappy said:I keep looking at that don't get the math. 170lb-ft is 170lb-ft. The only difference with the gearing is speed vs. rpm. I've heard of "torque multiplication" but just don't see the mathematical logic. I don't see how you can increase torque with gears, only placing where the torque/hp is relative to how fast one is going.
Any of our MEs want to chime in?
pappy said:Why wouldn't hp increase as well? Hp is a function of torque x rpm. If one goes up the other should too. Am I messing something?
...and conversely, how a 2.4L Formula 1 engine can make 800 HP @ 19,000 RPM but a max torque of only 200 lb-ft @ 17,000And the statements about HP being related to RPM help to explain how a D60 Detroit Diesel can run at 1,800 RPM, have 425 HP but 1,450 lbs-ft of torque.
Also
HP=( torque*RPM)/5250
But torque in its simplest terms is force X length of the lever arm. Gear reduction is effectively applying forces to increasingly longer lever arms.
So the gear box, in effect, functions to increase the lever arm. That I understand, though I still don't understand the physics of how that happens, because there really isn't a lever.
The leverage in a gear box comes from the different diameters of the gears; a small gear turning a large one has a lot of leverage, compared to gears of equal sizes.
