I just adjusted all the valve clearances, so at first I thought that was it, then a friend started telling me it might be a carb issue (since I recently took it off to fix an exhaust leak), then I wondered if the massive exhaust leak... that didn't get fixed... could be causing it.
what happens is:
If I give it gas and let the rpm climb a bit, right after I let off the the gas she kind of sputters, or backfires a little bit... not POP POP POP, but more muffled sounding. This is all in nuetral also, so the engine isn't really working hard.
I dont think its the valves, because I just checked them all.. some are relativly snug, but not overly so. It could be the carb, cause it got moved around quite a bit while doing the exhaust gasket... i'm just not sure.
possilbe diagnosis?
what happens is:
possilbe diagnosis?
