Here are a few other ones from the last year or so.
Bro that's ****ing rad
Pre-pump filter can be low-pressure, yes? Like one of those clear plastic jobs that will let you see the flow?Well, I knocked out the wiring for the fan today and got the temp sensor in the PS head. 5/16 pupe plug socket and the big impact made short work of the plug, then a little dope and the sensor went right back in.
The wiring is as tidy as I could get it. The PS inner fender is pretty crowded. May have to look at a shelf or something if much else need to go in.
So after that I dove into replacing the fuel pump.
First thing was to get a shut-off just outside the tank. Just in case.
Then all new Wilbro pump, new pre and post filters, and then tied back into the existing lines.
I made a big dang mess, but all done and no leaks, so win.
Victory was short lived I'm afraid. While the new fan and sensors seem to have taken care of any future overheating issues, the fuel pump has not helped my hesitation under acceleration issue.
Starts strong, idles a little high, then when you hit second at about half throttle its like it hits a wall. Lurches around and acts like it's starved for fuel. Let off, back to idle and it will putt along. I don't know alot about this motor, so I'm going to have to do some reading. TPI 350 is all I know.
Anybody got any ideas as to where to look. Fresh pump and it seems to run just fine. I don't think it's clogged at the tank. Should I be looking for a vacuum leak, checking the fuel pressure, .... im open to suggestions.
Thanks
Well the rabbit hole is deep. I'm learning. Like since the air filter is bolted straight to the throttle body, it is likely a 90-92 Corvette 350.
The fuel pressure guage doesn't lie. Right at 34 psi at idle, which is already below the 38 I've been able to find.
But drops to 20 psi when you Rev it.
I blipped it a few times and did a few second Rev, all consistently dropped to or below 20.
Also, as soon as I shut it off it immediately started dropping and was at 0 within a few minutes, so not holding pressure at all.
I'm kind of thinking that the reg failed first, which likely caused the last pump to fail.
Looks like I'm about to put a regulator diaphragm in and go from there.
Your on the right track with the fuel pressure, no amount of other work will make it right without enough pressure at the injectors.That's good to know. Still learning about these fancy fuel injection systems![]()
Well, was out of town this weekend so when we got home after some work on the tow rig, I pulled the upper intake to get ready to install the new regulator.
All this to get to the offender...
Nee diaphragm and gaskets should be here on Tuesday, then I'll get it swapped and we'll see how well it holds pressure.
Figure I'll get a fresh set of plugs in there while I got it torn down.
