Pulling hard left on acceleration
One wheel is driving unless the other one losses traction.
I don't, immediately, agree. I think Weber Sarge is more correct, but I'd hear your argument.
As I understand how it works, both axles should be driven when under load, and both axles should be 'active' under reverse load, or engine braking for lack of a better phrase. This makes sense to me after having had mine apart a couple times. The diff pin drives both side plates outwards whenever there is load.
I don't see any way that only one wheel could be driving. I do understand that if there's no load that one side plate could turn against the center. Mine is pretty easy to hear when it's 'slipping'. :rolleyes:
One wheel is always free to ratchet. In forward the slower wheel drives. It is BS that torque makes both sides lock. Roll down your window and do donuts in a parking lot. Keep applying more torque. You will hear it ratchet until one tire loses traction. Only then will both sides lock
Yea, but "one tire loses traction" at about 900 rpm and 0.25 mph. If you use the skinny pedal, at all, turning in an intersection you are lincoln locked in my experience. Maybe you're describing a detroit locker. (?)
They lock with torque, simple as that. You are as wrong now as before. They can ratchet around corners as long as they have no or little load on them. Try to accelerate in a corner while its free spooling and it WILL lock up. There is none of this one wheel drive till it slips jazz while driving in a straight line. They unlock in a corner, if driven correctly. If it was you would get some serious torque steer on the road.
Just do the experiment: Do a continuous turn accelerating in a parking lot from a stop with your windows down. Do not let off the gas pedal as it will cause it to switch drive sides. As you apply increasing torque, you will constantly hear the locker clicking, indicating that the faster wheel that is driven by contact with the pavement is ratcheting and is not "locked" together with other wheel. Only if you apply enough torque to cause a wheel to lose traction will both sides lock.
It is an easy experiment so there is no excuse for not doing it and just talking. Report back your results and we can discuss why it does not lock until one wheel slips. Once you understand that torque does not cause both sides to lock, then you can begin to understand how they work.
firstly i stole the picture for someone here on mud.
looking at the picture, what part of the diff assembly is going to transfer rotational energy from the ring gear to the locker assembly, which will then transfer it to the axles?
You can't see it in that picture. It is the contact of the center pin or pinion shaft with the elliptical cut out on the driver that transfers the drive.
and what is going to happen to the drivers with the oval cutouts and a round cross pin passing through them when power is applied? keeping in mind that both drivers are free to move away from the pin.
The driver of the slower rotating tire will be in contact with the pin and forced closed. The faster tire is driven faster by the its traction on the pavement and this moves the coupler out of contact, so it is no longer driven in any meaningful sense. If the rotational difference continues long enough, the free side will ratchet by one tooth.
The things that most of you don't get is that the tires are rotating at different speeds all the time if only slightly. It only takes a slight difference in speed to lose contact with the driver and pin. The other thing you are having trouble is that the faster tire is being driven by the contact with the pavement. That is why they only lock both sides when a tire loses traction. Because the tires are always rotating at slightly different speeds one side is driving and the other side is ratcheting all the time. They switch drive sides all the time too.
An advanced topic is what happens when you go from drive to coast and vice versa. The drive side switches.
Interesting I can't wrap my head around how it works either. I just assumes it was always locked and would unlock when no load was on it. How does putting thick shims in affect the locker I am running almost 0 thou on my locker And I very seldom ever hear it rachet or have it bang on the highway . I figured it was just staying locked. Haha Doh!
Mine actually has great road manners.
:cheers:
I said it previously - no axle can turn slower than the ring gear , ever - unless something breaks . Normal differential (open type with spider gears) will drive in a turn with the outer tire . Lockers of this type will drive off the inside tire when turning instead of the outside . The load upon a locker as said above forces the locking ring's half-moon cutout against the center pin(s) and locks the teeth into each other . The small springs are there to assist in unlocking during a no-load situation - such as one wheel needing to turn faster due to turning radius arc and the tires taking a different path to make a turn . Works the same exact way under deceleration - both axles are locked from force against the pin pushing the locker's teeth together , if turning while decelerating one axle is allowed to turn faster than the ring gear , never slower .
Got a headache yet ?
There used to be a video on the net somewhere that had a nice animation showing the function and direction of force in this type of locker , can't find it right now .
Sarge
We agree about the basics of operation. However, because one tire is almost always turning faster than the other when they both have traction, one side is driving and the other faster side is not driven by the ring gear but by the pavement. The reason for the side ways twitching or tail wagging during shifting is due to the fact that the drive side switches when you go from accelerate to coast to accelerate. The side switching is much smoother when turning from L to R or R to L because it always goes through a point where the wheels are turning the exact same speed.
Correct - "one side is driving and the other faster side is not driven by the ring gear but by the pavement" , this is the action of the springs in the locker - no load condition allows it to skip the teeth and act as a ratchet . This is where the shims in some are critical - shimmed tolerances dictate how well it can lock/unlock . Twitchy lunchbox units are set up too tight for the most part and of course some driving habits have to be changed . For instance , if you want smoother operation from one of these , push the clutch in earlier than normal to unload the driveline while the teeth are in thrust mode . For the most part this can help with the tail wag associated with gear changes . I have nothing against these lockers but if you ever drive in the winter it's a tough sell to use one . I've driven more than 20 miles in slushy/icy pavement about 30* sideways due to a lockrite . I always measured the circumference of my tires and paired them as close as possible as well . Switchable lockers are the only way to go other than price .
So , no news from the OP - how about some road test results ???
Sarge
Hi guys,
Just wanted to give you an update. I finally found the issue: had a loose shackle bolt on the rear axle. Once that was tightened down, the truck now tracks really nicely regardless of whether I'm on or off the gas. I scoured all kinds of forums for possible causes of thus sort of thing and, judging on others posted experiences, it seems that any play/loose driveline components can give you pulling when coming on or off the gas. Thanks all for your suggestions, your help is much appreciated.
Ernie
Just wanted to post another follow up: since tightening the shackle bolts, the problem has gone away completely and the truck is still tracking nice and straight. Despite having lunchbox lockers in both axles, the truck doesn't push to either side when going on or coming off of the gas. She drives really nicely, thanks for all the help and suggestions guys.
