The shift lever slides onto the pivot shaft and is retained by a cotter pin and flat washer. If it doesn't slide off, corrosion is the likely problem.
The pivot shaft is threaded into the cover.
Move the shifter front to back. Does the shaft move with the shifter?
Cool! So why’s the shaft so long and what’s the other hole for?
I’m planning to move a pto winch with all the linkage and shafts from a 1978 four speed to a 1971 three speed. It looks like there will be some modifications needed. Should I be worried?It is that long for a second shifter for a second PTO that bolts to the back. The early parts diagram showed both shifters.
Local like Seattle, WA and Lexington, KY? These things seem to be rare.Should be fairly easy. The driveshaft and rod on the shift linkage going to the PTO will both need to be shortened. More common going from a three speed to a four speed and may be able to find some one local to trade those two pieces.
