Hello thereThought I'd share a pic of a hinge I ground into a shift gate. It'll do until I find an OEM or Ehsan fabs one.
Peter
Not able to locate one till date. If there is someone here who an makepresentation of the piece, I can let my experts give it a try...Feel the love!
Thank you. Here is what I need. Someone put this thing onto a plain sheet of paper. Then trace the outer edge of the piece, scan it and post that up so I can print it out and get a sample made. The making would take approximately 2 days only. So I am waiting for someone to volunteer for the sketch.This![]()
picture of FJWagon's is the best representation I've seen.
You're not alone.
Leon...
Not being able to remove the gearbox I can't easily see from underneath if the H55F has the same mounting point as the earlier ones shown (H4x?) (the midline flange obscures the upper half of the case) - I suspect the H55F has the same outside casting and guess that I will be able to bolt the shift lever on in the same position but would like to hear from anyone who can confirm the application on this transmission.
