I’m considering installing a PTO driven winch on my FJ restoration. Do I need a special transfer case for this or Will all FJ transfer cases drive this winch? I noticed a cover on the front of the transfer case that looks like it has a PTO output shaft. I haven’t taken the cover off yet to look inside...
Stock transfer case with the correct PTO gear box and PTO gear in the transfer case. Mounts on the left side where the stock side cover is located. Carrier bearing mounts on the bracket under the radiator. OEM winch will mount on existing factory hole on the front frame rails.
You have to provide more details about your truck. Year, modifications, etc and "FJ" doesn't cut it. FJ25, FJ40, FJ55, FJ60, 70, 80, 100, or FJ cruiser? Which is it?
I would locate the winch first. Very possible when you find one it might come as a package deal. More the just the winch and PTO needed. Linkage to shift the PTO. Driveline between the winch and PTO. Also the special pillow block bearing also with other small parts. Your looking for a PTO to fit the one piece transfer case.
Upon closer inspection... I don’t think a PTO powered winch will work without modifications I’m not wanting to make... my exhaust header won’t allow for the driveshaft to run up front and my exhaust pipe is right in front of where the gearbox bolts to t case. Maybe electric winch one day... I love the old school mechanical winch. Maybe next restoration.
