Protecting paint after buffing
Santa Rosa, CA
If I go to all the trouble of buffing and polishing my heavily oxidized hood, hoe do I protect it. I don't want to have to wax it every month. Can I spray rattle can clear on it and have it work?
That is interesting stuff. I had never heard of it, thanks for the information.
How would you compare that to using rattle can clear coat?
What do you recommend for buffing out heavily oxidized paint?
You would never clear coat a polished surface unless you want to have fun pulling it off as it peels.
Just wax it.
Even if you got the clear to stick it would break down in a very short time.
If you do paint you will need to sand the polished area first to give some tooth.
Remove the wax residue first with dish washing detergent and a rubbing alcohol bath .
Never sand a waxed finish or you will never be able to thoroughly clean it.
Coming from the boating world I've learned most of the coatings that use fancy buzz words and promise long life and ease of application typically don't work for extended use. I also dislike applying unknown stuff to a paint finish. A good cleaning then a good polish followed by a good wax works well.
Coming from the boating world I've learned most of the coatings that use fancy buzz words and promise long life and ease of application typically don't work for extended use. I also dislike applying unknown stuff to a paint finish. A good cleaning then a good wax followed by a good polish works well.
Polish and then wax.
Rattle can is not worth the effort. It isn't that smooth, and it doesn't stick well. You can easily remove it with acetone, but not factory paint. Meguires, or Boeshield to protect from oxidation.
That being said, I really dig rattle can, but not rattle clear coat.
