Build Project Lockjaw-1973 Fj40 on Tons
Member Build Threads
Hopefully it will be fixed soon. I've reached out to some of the guys on Langmuir Forum and have some tests to conduct on my plasma cutter.
Link to the langmuir thread? I can chime in there.
Never delete your fusion projects, just mark them non-editable :)
Posted in the firing issues thread as well.
@GLTHFJ60 , Hey Johnny do you have any recommendations on where to order consumables on the internet? The welding supply stores are expensive as heck
Amazon is usually where I go. Look up the consumable part number from your manual right on Amazon and you'll see kits.
Ive had good luck with them.
got the file back into my editable documents on Fusion360. However, I don't see a non-editable tab to save it. There is a drop down that is "read only" and when I click on it, the file disappears. Have no idea where it goes to when that happens or how to retrieve it.
Click the circled button and your projects come up (if you have them organized).
Then click this button (will show editable at first) and select read-only. As you can see, mine stay right here:
Awesome, thanks sir. Still figuring things out
Got some work done last night on the project. Rear floor in and side panels welded in.
Finished up the front of the rear fender wells. Panel replacement is almost finished.
Looks good coming together !!
Front axle truss getting ready to go on. Mocking up the front upper link also
Finally decided to pull the trigger on cutting the two tops. Can't wait to get this thing rolling
Did you make that truss or buy it?
Actually bought it from a local off-road shop and its a Barnes4wd. Maybe one day I can start making these !!!!
Looking for a fiberglass top cap for my 40 project. Willing to drive within a 200 mile radius of Knoxville TN. Let me know. Need the front 3/4 or so to stretch the one I'm getting locally. It has a sunroof, so I'll be using the back 3/4 of it.
