some details
camcruiser13 said:
explain in more detail please
All this is copy and paste from the Tech links
http://www.ih8mud.com/tech/soa/index.html
[FONT=Arial,Helvetica][SIZE=-1]Overview:[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]Cutting and turning is probably the most difficult and most “feared” aspect of a spring over. But in reality,
if done correctly, it is not that hard at all, and I believe any rig lifted over 5” should have it done, regardless of whether it is sprung over or under. It provides such a big advantage, especially in the case of a spring over, and since you are already there so you might as well do it right the first time.[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]If you think that you are not up for the task of cutting and turning, several companies cut and turn axles for people, including
Cruiser Outfitters and
Proffitt's Cruiser's. Proffitt's even offers a SOA kit. It is usually about $150-$200 to buy a cut and turned axle + core charge.[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]**If you are thinking of doing a Shackle reversal (see
page 7 later in the article to read about them), do the shackle reversal BEFORE you take measurements for your cut and turn.[/SIZE][/FONT]
__________________________
[FONT=Arial,Helvetica][SIZE=-1]A good, unofficial description of cutting and turning is basically: "a way to correct your steering on your front axle because you are rotating your pinion up toward your transfer case."[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]Because you are lifting your rig so much, it will create fairly "extreme" front axle angles if you do not cut and turn. Here is a photo of an axle before cutting and turning - you will see the front pinion output is level - exiting at 90 degrees. Because you are lifting the rig so high, you want to rotate the pinion up, out of the way of rocks, and up, towards to the transfer case front output, to get a better u-joint angle. Otherwise it can bind and cause something to break.[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]A front axle, sprung over, before cutting and turning, with the weight of the [/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]vehicle sitting on the front axle using jack stands:[/SIZE][/FONT]
