Preload set too high?
Twin Cities
Website
www.myspace.com
I did the front axle last week and found that, when setting the inner nut to 10 lb the preload was way beyond what my fish scale would even register (25lb). We backed off, tried 5 lb and found the same. Then we went to 45 lb to make sure the bearings were set, backed off, spun, torqued to 10 lb, etc. we found that even when there was no torque it was really stiff to spin. We gave up on one side and moved on to the other to see what we'd find there with the same process - same thing, preload really high with next to no torque on the nut.
I went with non-synthetic bearing grease and it was getting pretty cold that night, could cold grease be the cause? Too much grease?
We put it all back together and I've driven it around a few miles with no grinding. Coasting might be a little hindered from what I remember but that could be the new beefy 100-series pads that we put on (those things barely slide on the rotors!).
Could I be in for an exploded bearing?:eek:
the grease seal on the backing plate can fold over and cause a lot of binding on the hub. I'd pull it back apart and mke sure that didn't happen.
Pardon my ignorance, but what part is the grease seal on the backing plate? Is it the seal that I tapped in over the inside bearing?
It doesn't feel like it's binding on anything, just smooth and tight. Would I feel some binding if this were the case? Is it likely that this could happen with both sides?
Stupid question...you are taking your measurements with the caliper OFF, right?
Yes, caliper off.
the grease seal has a metal ring with 6 bolts that goes through it. The hub actually slides into it. The problem is that while you are sliding the hub onto the spindle it's not centered do to the taper of the bearings. The edge of the hub grabs onto the seal and folds it over. Now the rubber seal is dragging on the hub giving resistance. This exact thing happened to me.
Yes, caliper off.
No, the one in back... that attaches at the same time you bolted the spindle back on?
Hey are you saying you get the same readings on both sides? What about temperature.. if you drive for a few miles, stop, then run out and touch your rim is it hot? Hotter than the back? Hotter on one side than the other?
The preload was beyond my fish scale but both sides felt about the same. I haven't checked the temperature on the rim or hub. I'll have to check on this next week as I don't have the time before Friday. (A friend of mine wanted to borrow the truck tomorrow so I figured that I'd get the question out but I've figured other arrangements for him.)
Are you sure you have the races seated at the proper depth?
I seated the races fully to the iron lip in the hub. I hope that's the proper depth...
I'll have to tear into it later, just need to find that 54 mm socket (borrowed jjcobm's last time)... Checked Autozone and O'reilly today, neither of them have it.
Just so you know,
I heard that one 55mm you had rented will work just fine:D
I helped flem here with the axle rebuild. It was really odd as the resistance was really high when trying to spin the hub. The temp must of been around 45-50F.
I didn't double check that bearing rear bearing seal, but it sounds like that would be a problem. My best guess at the moment was that the wheel bearing grease was way to cold, and that he might had used synthetic ( i read this somewhere). But no, the fish scale was reading way over 20 and that hub wouldn't rotate. And it was attached to the wheel studs.
I would best guess that seal like someone here posted.
Did you just check it again recently flem? I was hoping the problem would go away after running the truck and letting the grease settle/warm up some. I hope the problem is still not there after you drove it around some?
Races are seated until they won't go in anymore...the bottom lip where they seat to is correct...the upper lip they pass on the way in (and recess a bit) is not correct.
We took it out around the neighborhood to get pumpkins over the weekend and that was it. I haven't checked anything out since. No time to check that but I seem to find the time to surf mud for answers... hmmm, where are my priorities.
jjcobm was watching over me so I didn't royally screw anything up but the grease seal is something we didn't check on.
Hopefully next week will be nice so I can tend to her, maybe even give her a bath and shine up her bling...
If you drive with that seal folded over it is likely it will cut after rolling for a while...as me how I know :)
I'm afraid to ask how you know.... Oh f:censor:...Hope the damage isn't already done.
:doh:
Flem.... your addicted to mud buddy. Check your hub!!!! :lol:
I've had this addiction for a while; I should probably get some help.
And so should all of you with your thousands of posts!!!
Nahh, just kidding, without all of your posts us newbies would be breaking more than a grease seal here or there (and an ABS sensor...oops).
No way cold grease or that rear seal could impede the hub enough to make it that hard to rotate. My next guess, and with all due respect, is that you didn't interpret the directions right and you overtightened the inner nut. The directions call for you to torque it the first time to seat the assembly, then you back it off to hand tight. When you retorque the first nut again, its not to 48 FT LBS, its to 48 INCH POUNDS, and if that's what you did, I wouldn't drive it 10 feet without fixing it.
You should then be able to check your preload and get within the ~6.4-12.6 range. Then you install the star washer and tighten and torque the outer nut to the higher 47 FT LBS of torque. This jam-locks the outer nut against the inner nut, but should have very minimal impact on the preload. But just to be sure, the FSM instructs you to check it again, and you should be in the 9-12 range. End result is 47 FT LBS on the outer nut, but only ~48 IN LBs on the hub itself.
I think Landtank's method was the same as mine.
Tighten the inner nut to 45 lbs/ft, rotate, back off and repeat, then just until you feel resistance. Install the lock washer, then torque the outer nut to 45 lbs/ft.
I use a torque wrench for Cruisers because you need to use the socket. It's easy to get carried away with a 1/2 ratchet.
With cars and trailers I use a pair of channel locks. I've found that I get better feel for the pre-load torque.
The rear bearings do require the special alien landing ship tool.
This is the method that we used to tighten the inner nut. If i remember right, even after flem and i tried to back off the nut completely, there was alot of resistance to rotate the hub. Only way it would be normal was if you removed the hub and remounted it without the tightening the nut at all.
This might sound like a bad question, but i don't mean it in that way either, but would it be possible those bearings were not installed properly? I didn't oversee that part and it makes me wonder if by any chance this could be the cause of it. Maybe an improperly seated bearing would be my best guess because i am very doubtful of that oil seal causing the amount of friction i felt too.
Like i said, that fish scale would not even move the hub a bit even when reading 20.
Either way, we will just have to wait for him to dig in again and find out what the problem was....
Torque method
Land tanks method seemed to work for me as well. I torqued the inner nut to set it. Backed it off and tightened it just until I literaly felt resistance then stopped. Torqued the outer nut to 47 Ft Lbs and that measured 12 lbs on the scale. When I tried to torque the inner nut to 10 Ft Lbs then the outer to 47 Ft Lbs, it ended up taking more than 12 lbs of pull to get it to turn.
You definitely want to check them after 100mi or so as instructed in the FAQ. My passenger side lossened up a little so I had to retorque that side.
Can I reuse the gasket on the flange and the tabbed washer when I put it back together?
Depends on whether or not the gasket is already saturated, but I would say yes. Star washer can usually be reused once. Just make sure you have at least two good tabs, one for bending out and one bending in.
Tore into it tonight and found that the preload was around 14 lb on the drivers side. I adjusted it and now it's about 11 lb. When checking the passenger side I found it was already around 11 lb so I left it alone. Plan to check again in 100 miles.
All back together with a new abs sensor on the passenger side and the ABS light is no longer on.
Thanks to everyone for your advice and especially to Jacob for his assistance and words of wisdom.
Now I'm painting up the running boards to put them back on for the :princess: - she's 3 months along (with our first child) and hopping up in the rig without a step will get to be a challenge.
