Preload set too high?
Hot Hub!!
So I took the truck into work today ~ 13 miles mostly highway. Upon arriving I checked the hubs with my hand. The driver's side (the one that I dug into and adjusted the preload yesterday) was mildly warm. The Passenger's side hub was too hot to hold my hand on for any length of time. I dug into that one as well yesterday and found that the preload was right about at 12 so I left it alone. Also, I replaced the pads with the 100-series ones and found that the passenger side set was dragging a little on the rotor, more so than the driver's side set.
So, is too hot to hold too hot for the bearings? Should I tear into it again before going to far or just wait for 100 miles when I plan to recheck anyways?
Could it just be the rotor heating up from the pads and convecting the heat to the hub? I didn't feel the rotors as the fact that the pads were dragging on the PS just occurred to me here in the office.
I had a problem with one of the rear calipers dragging and after driving home the hub on that wheel was too hot to touch. It could be the brakes if everything else seems to check out.
I have never had one run hot after a rebuild. But I don't trust my life and my 5000 lb truck to a fish scale or to my "touch." I bought a $20 force gauge on eBay and I use the FSM religiously so I know its right when I reassemble it.
13miles and on the highway going at around 60-70mph .... I would say if those pads are still rubbing the way they were when we slapped them on, it would definetly cause things to heat up, especially if you were using your brakes (remeber rotors also contact the hub so there's heat transferring there.)
If i were you I would just check back at 100miles like you should anyways. Now you only have what, 100 more miles to go minus the 13 right (87)? When you do check them in 87 miles, you can see how the preload is doing and pull out the hub to see if there is still anything odd.
Everything was greased up adequatly so it's not an issue of no lubrication. Preload was set to be at 12ft/lb and that nut was definetly torqued down.
:beer:
