Well that fortunately went very smooth. Huge thanks to the pioneers, was able to convert my 2002 Nav using a 3 knob panel from a 99, adding a Sony XAV-AX1000 receiver. I kept the factory amp and speakers, so used the aforementioned metra harness. I will attach a little file I made for myself with the relevant pictures and parts (I know these things have been posted earlier in the thread, but maybe the consolidation will help.)
The only hiccup for me was, even though I knew to keep an eye out for the 3 wire connection, I managed to miss it anyway, so had to make another splice. Still works fine.
A couple additional notes:
-For all but the 4-wire and 3-wire connections, the red heat sleeves are the perfect size. The blue ones are perfect for the two bigger connections.
-On the metra harness, you can combine both the blue and blue/white wires, and connect them to the new stereos remote wire. This way your antenna will automatically go up and down when the stereo powers on/off. That may be obvious to you but I had to do some research to learn that.
Two things I still need to tackle:
-Still need to wire up a backup camera. I am using the one others have posted, now available on
Amazon, that replaces one of the license plate lights.
Backup camera: direct replacement for license plate light
-The sound quality seems worse than with the stock stereo. Less full bass and low-mids appreciable from the front seats, yet overly bassy from the rear. I will play with the EQ some more but I am wondering if there is some kind of integration between the stock stereo and amp system that is now lost....maybe will have to replace the rest of the system.
