Power windows just died.
Logan Utah
i haven’t driven the 80 in awhile, I hopped in and it fired right up. I rolled down the windows and went for a spin parked it and tried to roll the windows up and nothing happens from any of the switches. My question is where do I start trouble shooting?
Can be the door controll module located behind the interior panel of the drivers door. Do a search, you can remove one of the relays in the driver's kick panel and use a jumper to bypass it and get them working again (although it will keep the auto down switch for the drivers window lit and drain your battery slowly if you keep it like that). I gues's it could also be that relay.
AC still working?
Sunroof work?
Dash lights still work?
All those are on the same fuse, or at least on a '94.
Clean carbon deposits from driver's window switch.
Key in ON position???? Kidding.
On a 97 AC and radio are on two fuse circuits, IF I recall correctly, perhaps window on one of these two. There are 2 fuse boxes.
the radio works... where is the second fuse box? i only remember the panel next to my knee...
Dont all other window switches go through the master switch (hence "master")?? If so, problem is in the master.
Been a while since I've delt with this bugger.
