Power window homebrew fix!
The NW, Cascade Mountian Range
This is a drawing I made of 4 relays, desinged to work together so only 2 wires connect to a window motor. the poles + and - reverse, so the motor operates up and down.
I just wired this up in my truck for the driver window. it works good. it is important to wire it to switched power, cause two of the relays stay on while the switch is off.
You can use it for any power window.
you can substitute the 25A fuses for 15A or 20 A
while brewing this up, I could have used a switch, alone, but I get more satisfaction doing it my way.
its a lot cleaner looking once the circuit is built. you can see my test motor there, along with the momentary double throw double pole. you can use a momentary double throw single pole, if you want.
im no artist, i know the drawing is kind of sloppy. but the effectiveness of the circuit is 100%!
I believe this is to replace the relays that make the rear window work, they tend to fail eventually. Mike's solution is much more durable. I don't like Wristy's "2 relays stay energized" method, but eh... it's not that big of a deal.
For relays that matter, I go to McMaster-Carr. Stay away from the crap that Radio Shack sells.
Well that I could see but Wristy said "driver's side window" which is why I asked.
I must have missed the "Why do this?" part of the thread. LOL
why i did it cause the PO jacked up the window sw so bad i didnt have all the parts to fix it, and it the wires to it were so jacked up i didnt wanna deal wit it so i cut em out and ran the new ones.
i linked this thread for the newb so he could get an idea of how to fix his deal. DUH! L:lol:L
i designed the circuit to alternate polarity. it can be used on any motor
Where do you mount the new switches? where ever you want
Where do you mount the relays, once they are taped up they take up some room. i mouned mine behind my stereo, kinda on the floor.
how do I know what relays to purchase? bosch style
How do I get to the motor in the sun rooof? pull the head liner, use some tools in the right spots
the relays use these numbered terminals. 30, 85, 87, 87a, 86
try frys electronics. or go to the junk yard and find some.
wouldn't it be simpler this way?
- 2 Bosch style relays, 1 switch
- motor has ground on both sides when relays aren't energized, switch provides ground to activate relay
- move the switch in one direction, 1 relay is energized and supplies power to one side of motor, other relay provides ground path - reverse scenario for the other direction
. . . is there any reason this wouldn't work?
You could have constant power to the relays with no battery drain
the first relay for the up, is connected to 87 and when you switch to down, it remains in 87. you have to have the 87a in there cause these relays are normally closed in the 30 to 87 position.
looks yer design wont work. but i wouldnt mind building something similar
when you switch it to down the 1st relay is connected to 87 and ground, the second relay energizes and connects to 87a and voltage, so polarity reverses and the motor turns the opposite way - - this is actually a common dual relay power door lock circuit which reverses polarity to make the actuator move one way or the other based on switch input
hell you boys are making every thing so difficult. i have no drawings but all you gotta do is reach over with your left hand and turn that there cranky thing and the window goes up. unless you are a passenger then you have to use the right hand to turn the little cranky thing.
don't forget the latch and slide if you're in the back seat of a 1st gen 4runner
For relays that matter, I go to McMaster-Carr. Stay away from the **** that Radio Shack sells.
DigiKey Corp. also sells relays, switches and other electronic parts.
As the simple design just uses automotive relays I'd go that way and pick them up at the local auto parts store if they aren't priced insanely. If you don't want to bother with sockets, just get the blade type quick connect contact and use faston connectors. Automotive relays can be bought with a mounting tab in either metal or plastic.
This is a Tyco SPDT automotive relay, 30A @ 12VDC: Digi-Key - PB686-ND: If you go to the catalog page you will see sockets and terminals for them. Digikey is $2.93 each but orders under $25 are assessed $5 handling.
PS: don't forget to use dielectric grease on the contacts to keep em from corroding.
