F it! im breakin the glass out right now!
wouldn't it be simpler this way?
- 2 Bosch style relays, 1 switch
- motor has ground on both sides when relays aren't energized, switch provides ground to activate relay
- move the switch in one direction, 1 relay is energized and supplies power to one side of motor, other relay provides ground path - reverse scenario for the other direction
. . . is there any reason this wouldn't work?
You could have constant power to the relays with no battery drain
