- Thread starter
- #1
Total noob with Land Cruisers here. I purchased my 93 TLC about a month ago and noticed at the time that the rear power windows would not roll up or down. I've searched extensively and didn't find any similar problems. The PO told me he removed an aftermarket alarm system that was draining the battery and after the removal the rear windows wouldn't work. He tried to figure out what happened, but gave up when he couldn't find any obvious wiring problems.
Both front windows work as does the lockout on the drivers door control. The rear window motors work with a 12V power supply directly to them. It doesn't appear to be the window switches either as I swapped the passenger control with both rear controls. I've traced the wiring to the kick panel loom and didn't see any damaged wires.
I don't have a wiring diagram to figure out if there is a separate power wire for the rear windows. Would a bad main relay (drivers kick panel) cause problems with only the rear windows? Would a bad fuse cause only the rear windows to not work? I'm having a hard time wrapping my head around why only the rear windows have been impacted. Any help would be appreciated.
Mike
Mike
