Power Steering Leak
Hawaii Island
My 99 LC has had a power steering leak for a couple of months. Not bad but recently I have noticed that it is getting worse, to the point of putting fluid in it every other day. I’ve been looking through the posts here and saw that possibly I can use a stop leak additive and that might help. I am in the process of cleaning the engine bay and noticed that there is a small hose that is not connected. I’m assuming that it is the ps pump that this hose goes to. I took a couple of pictures and maybe one of you more knowledgeable guys can verify that for me. Once I have it cleaned up hopefully I can find the leak and go from there. I am hoping that it is a hose as opposed to the whole steering rack being replaced as I don’t have the funds for that job.
Anyway thanks in advance for any input!
That black nut in the third pic is a banjo bolt. Feeds the fluid into the pump. There should be two crush washers that go on either side of that banjo fitting. I can’t tell from the picture if the are there. Or maybe if they there then they were old but not replaced during maintenance.
I just looked at mine. If I stand in front of my headlight and look down onto the bolt, I can see my crush washer. I need a flashlight though.
This might be a better picture. Looks like a washer underneath. Can’t tell if it’s more than one though.
Are you talking about the larger one or the smaller one at about 11 o’clock in this picture. The one to the left has a double fitting that has two small hoses that attach to it. In this picture it shows one of the hoses disconnected. I saw that one earlier and put it back on. I had radiator and alternator installed a few days ago. I don’t remember it being like that before I had it in the shop.
Are you talking about the larger one or the smaller one at about 11 o’clock in this picture. The one to the left has a double fitting that has two small hoses that attach to it. In this picture it shows one of the hoses disconnected. I saw that one earlier and put it back on. I had radiator and alternator installed a few days ago. I don’t remember it being like that before I had it in the shop. View attachment 4047225
