Possible Group Buy - Flat Steel FJ40 Rear Fender Protection
Ok it's a stock look then, was getting confused with all the axle move talk i guess. The only change would be hole locations since there's no lip under the fender to attach.
Yes. If I were you, I'd weld some sheet metal tabs onto the bottom of what you have and have the fender protection overlap (barely) what's left. One or two of my bolt holes only catch the sheet metal by half or less of a hole. I use a big washer so it holds on enough.
Maybe post a pic of what you've got.
Update: I dropped one of my flares at a shop that @pjohnson pointed me to. They have a $600k laser cutter. :)
Please respond with current interest. The guy said he could do the counter-sinks for a reasonable price as well, so those will probably be s small cost-add option. $20/set
$235/set unless we get four sets at once.
The holes are kinda random. As I recall I wanted three across the top, so I spaced them evenly to make that happen. The hole at the front is not drilled by the mfg so the installer can choose to move it around as necessary based on placement fore-and-aft.
