1973 Toyota fj40 Land Cruiser for sale or trade
1973 Toyota Land Cruiser fj40 with V8 conversion with TH350 transmission with bump shifter. Frame and under body completely rust free with POR 15 and undercoat. Eighty percent of all nuts and bolts...
bakersfield.craigslist.org
What do you guys think. Pics aren't best but maybe can see some things.
He says wiring needs to be done. Has been hooked up to run engine but since been disconnected. Top is in good shape but mismatched sides, one is for a hatch and one is for ambulance doors.
Obviously the swap isn't ideal for purists. He says engine ran when it was taken out two years ago.
Got some more information.
The tub has been replaced with one from a 69. No rust but it's coated top/bottom with some sort of rhino lining. He says all the brakes/lines are installed just needs the Master cylinder installed and final plumbing.
Has parts for a saginaw kit except some mounts or something but most of it's there.
Mentioned on the older tub where it passes through the firewall is different?
Full wiring needs to be done but he has a new harness from a 76. Not sure how that interchanges with the older model but the engine swap obviously needs more work.
