possible 73...thoughts?
Bakersfield, Ca
What do you guys think. Pics aren't best but maybe can see some things.
He says wiring needs to be done. Has been hooked up to run engine but since been disconnected. Top is in good shape but mismatched sides, one is for a hatch and one is for ambulance doors.
Obviously the swap isn't ideal for purists. He says engine ran when it was taken out two years ago.
Got some more information.
The tub has been replaced with one from a 69. No rust but it's coated top/bottom with some sort of rhino lining. He says all the brakes/lines are installed just needs the Master cylinder installed and final plumbing.
Has parts for a saginaw kit except some mounts or something but most of it's there.
Mentioned on the older tub where it passes through the firewall is different?
Full wiring needs to be done but he has a new harness from a 76. Not sure how that interchanges with the older model but the engine swap obviously needs more work.
Well, there's a lot of potential there. If the body is in good shape (minimal rust), then I think what the seller is asking is within a reasonable range. It comes with a lot of parts and you're getting the original motor and trans which is a plus. You could either go back to factory original or finish the wiring on the replacement motor. Given that it's not ready to run and drive as is, maybe offer $5 or $6K? Overall, doesn't look too bad.
Looks like a nice start with the potential to be a great rig. Since you can't a road test and there are a lot of unknowns, I would shoot for a lower purchase price, but I don't think the seller is too far off the mark. To me, the money is in rust-free sheet metal and a pre-smog frame with a clean title. It wouldn't take much to fire the engine before you buy.
The CA DMV has a fee calculator on their website and you should double check to ensure there are no back fees.
I think if it is solid and complete is stated it is worth the $$$ as opposed to buying a Rusted POS with hacks.
The Hard Tops are selling for close to $2k on their own these days so taking into account a lot of them don't come with that really you are paying like $5k for a soft top which is still a good deal. Of course less is better and it reads like $6500 is is start price so I would think $5500 is not out of the question.
Always best to start with the best base you can get as it will be worth it in the long run.
Ohhh well his value just went down as now it is not just an unfinished project it is a franken cruiser that he is probably stopping as he has $$$ left to spend and isn't necessarily happy with some of his project decisions.
I say hit him at $4k and you should have a good rig at under $10k . It will never be a viable resto project if you want back to factory spec but it will be a sweet cruiser you can enjoy .
this reminds me of the 73 I looked at once, he added ambi doors because it "looked cool". they didn't close properly.. and he couldn't get the fuel pump to work so he piped one up into the cap so he could shake it when id stopped, which he said happened a lot. fuse blocks, bondo, 3 shades of paint, wrong doors. when the list starts getting bigger, check if you want to do all that... :confused:
Good points.
It still has the lift up rear hatch and supposedly the top will all go together just doesn't have the gaskets for it.
Yeah it wouldn't be a frame off restoration but don't know if I want to mess with a bunch of different stuff either.
Good points.
Just an FYI, the hardtop gasket is probably the single most expensive gasket on a 40, usually around $400 +/_ for a OEM or equal.
I'll modify my earlier comments to add that ANY coating (Rhino Lining, etc.) puts any tub out of the 'rust-free' category for me. If I can't verify it, it's not true. While it may be perfectly fine, the tub is a crap shoot. Everything else you can verify.
The '73 switches are not going to plug into the '76 harness, particularly the things you NEED, like ignition, wipers and headlights. That said, you can still find the '76 switches if you have the patience. Headlight switches are in the hen's teeth category, but they are out there.
As long as you're happy with what you're getting, understand it's a 'project' and have the skills, tools and patience to put it all together, it's a good start (for the right price).
Nobody noticed this is not a 73. Tool box under driver's seat and no door on the fuel fill are pre 73. The four would not be correct for a 73 in the US. What is a all matching number? Mention it right after saying he had the original engine and four speed transmission. May be a 8/72 titled as a 73 but would verify what the tag on the a pillar says. Should be a VIN plaque on the passenger's side front fender. Could be buying something somebody put together with parts he had.
guessing he is running a 73 title off the chassis
There is a challenge with automatics, you have to keep the transfer case properly sealed to segregate the two oils. Ask about the drive shaft lengths. I always wonder if they locate the drivetrain properly in regard to the driveshaft angles and lengths. How good are the motor mounts? How much do you have to do to get that 2F in there (looks like a 2F from later years). A '73-title shouldn't come with a 4-speed either, so there may be less clearance for the transmission regarding the frame's cross-member. A '73 came with a different roll bar. That style of transfer case shifter was used with 4-speeds up until April of '75.
It could be a great deal, but, it could destroy you if something is not asked, or something is not true. The frame number is critical, for me. The other tags on the body are associated with the '73, so you already know that they might have at least been transferred/tampered with if the cowl isn't original, but the A-pillar tag is. If it really is, "all numbers match," then that should include the motor, and transfer case(s) as well.
There was no roll bar in the 73 model. Those started in the US 9/73 with the 74 model. If we're a true 73 a four speed would fit. Some markets got a four speed in 73. Because I see no radio opening in the dash and wrong fuel fill would say this is a earlier than 73 tub. With a 73 frame it would be less challenging to get a four speed in.
@Living in the Past is right on with his assessment the tub is not a 1973.
I would check the VIN (and frame number, which must be the same as the VIN) against the SOR list.
One sure fire way to determine if the frame is Jan 1973 or later is in the torque tube. My FJ40 came with a 3 speed trans., but had the "yoke" in the torque tube to accommodate the 4 speed trans.
Somewhat off topic but I found a decent 71 that needs an engine.
The guy said he'd sell this one with 4 speed and transfer case. What do you guys think it's worth. Obviously depends on condition but assuming it's all operable.
From looking this setup would fit and work in the 71?
@Living in the Past @Dizzy @reddingcruiser
If you asking about a four speed not direct dropped in but did this to my 68 a long time ago. Further service is harder than 73+ that were made for a four speed. As for a value, no engine without pictures have no clue.
Not all 4-speeds are the same. What year are the gear boxes from? Also, you will need to have driveshafts of the proper length, which can be fabricated. How much of the engine is there? Do you even get as much as a bellhousing?
@bhsdriller you ultimately have to decide what you want to end up with.
If you want to end up with a mostly stock 40 I would start with a rig that is as complete as possible.
If you want a resto-mod with a SBC and A/T, or some variation, I would start with a clean, titled frame with good sheet metal and a junk (or missing) engine and transmission/t-case.
Anyway, rust - free rolling frame and sheet metal only with minor dents and dings, clean current title, I generally look to spend $2k to $4k depending on how complete and condition of the interior. However, I've paid more for top notch rollers.
I don't know if you've done this before, but a lot of folks greatly underestimate the cost of putting a 40 back together. Just be sure you're being honest about how much you'll have invested if you go the build route.
FWIW, I hate rust. I would rather put together a complete drive train than fix one rear sill.
