Polyurethane bushings.
Washington
Ok yes I know, "Go OEM" but that is not what I am after with this particular use.
So I am looking at polyurethane bushings and Whiteline has a couple of different options. They have a simple 2 piece bushing and then a single bushing encased in metal. I live chatted with their tech support who seemed pretty clueless about why you would want one over the other, or of any differences between the two so I figure someone here probably has experience with them maybe on a different platform. SO which one is preferred, better, best?
i have used them in other projects and they were always noisy. if that is something you can deal with then go for it but for me it was annoying as hell.
I would think the 2 peice might flex a little better, wear a little faster, but are also easier to replace.
The 2-piece type would be my last choice. The bonded sleeves (like the OME CC bushings) seem to keep things quiet in my experience - especially if inner and outer sleeves are both bonded.
This is spot on, we sell and install white line at work. Steel bonded is just harder to fit and will flex less, make sure you use there grease that comes in the packet
I used the poly bushes on one of P38 Range Rovers and it completely destroyed the ride. Noisey and very hard. Swore I wouldn't use them again. I think even aftermarket rubber is a better option.
