I am in the process of converting to PS on my 76 FJ40, the nut from the original box does not fit on the new PS box, can anybody tell me what size nut/thread pitch goes on the end of the this power steering box. And the bet place to get one?
Call Dan or Beno at American Toyota in Albuquerque NM. I'm pretty sure the dealer can get that nut for you.
If you're in a hurry, go to the parts counter at the local dealer. Maybe call and get the part number for best results.
What is the application of the steering gear?
If the stock nut does not fit, how are they going to find the correct one not knowing what the steering gear is off?
Dan is good; however, he is far from omnipotent.
Looks like a minitruck box. Maybe Toyota would have a nut to fit on it?
Maybe it's not the same as the nut from the manual box it's replacing?
Maybe a smart guy from around here could be more helpful?
On these conversions I have done in the past, I have not had this issue.
You mean omniscient?
Are those Nylon lock nuts I see holding that box down to the pedestal? Scary.
Lock washers and 100% steel class 10.9 nuts would be a better choice.
The nylock nuts don't have as much threaded area as a regular nut. I wouldn't use them in a critical role like the steering box.
You certainly have a point about thread depth Eddy.
