- Thread starter
- #21
@diesellibrarian I set timing per your recommendation and my idle dropped to a still-not-normal 800~ which is much better than 1100-1200! I’ll be doing valves soon. Maybe a slight change in the stumbling, bogging, and backfiring.. less pronounced but still happening. Thank you.
I went through with a multimeter and tested the ICV, TPS, and AFM.. all testing within spec. Picked up a vacuum gauge and it’s reading around 18-19 Hg at idle which seems in the normal range. Stabbing at the pedal it would fall but come right back up, giving it steady input it mostly stayed the same.
Thinking I’ll check plugs, wires, do a valve adjustment, and then maybe pick up a fuel pressure gauge. Really wanted to take this thing out camping this weekend. Bummer.
